Not so inoccent random PM's (from Emma ?) PLZ READ ITS A REAL ISSUE
Message added by vanished
We are aware of this problem and are actively working to eliminate it as best we can.
Do not make any more threads about this issue.  This is now the main topic and additional threads will just be merged into this one if found.
If you receive one of these PMs,
  • Do not click any links
  • Do not reply
  • Report it using the links/buttons available so we are made aware (example below)
  • Delete it
If you see one of these profiles:
  • Do not post on their page
  • Report any spam status updates on the page
  • If the account is more than 24 hours old and there is no spam on the page, it is almost certainly banned, even if you cannot see it.  Again, refer to recommendation 1 above
If you received a notification for a PM, but the PM does not exist, it was almost certainly due to one of these and can be safely ignored.
If you received what appeared to be spam email from LTT, please understand that we do not send spam, but if you have elected to receive email notifications of PMs, you will receive an email about PMs, including this PM which is spam.
10 hours ago, LogicalDrm said:
Well, not that unexpected. I would say we get the waves few times a year. This is extensive one, and mainly since it targets PM system. The Moderators have quick ways to deal with common spam. It removes account and all of their posts. However it doesn't remove PMs sent. So while NA/AUS/NZ based Moderators have already banned many of the bots, PMs sent can still be there. Making this look like a continuing issue (when it necessarily isn't).
It was an over exaggeration to get the point across.
I`ve had these PM`s on about 6 different forums now, (mainly Flight sim Forums).
Took me about 1/2 a second to recognise it for what it was, then click delete.
Not the end of the world, and she did have nice ermmm Eyes....?
Good to know it's not just us, I guess.
6 hours ago, wkdpaul said:
Damn .. looks like I missed the party!!!
I got "invited" by a Emas595. I wasn't interested. If I knew you wanted to go I would have offered you my invitation.
I think the real question is how can you cosplay nude? isn't that like when you dress up?
Hi Bhosted,
Emmi756 has sent you a message!
Read full message
— Linus Tech Tips
What is this nonsense? Seems like she spammed all of us.
2 minutes ago, Bhosted said:
Hi Bhosted,
Read full message
— Linus Tech Tips
topic merged
Well you could cosplay as a nudist, or a nude character ;)
Nudist Beach time ?
Tho if ur nipples aren't glowing purple it's finna be a 0/10 cosplay ?
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
Was there not two or three obvious bots making accounts yesterday in the activity feed yesterday  ? I am pretty sure I seen that. There are a bunch of Emmas and some number from what I seen
20 hours ago, Morgan MLGman said:
If you have any specific recommendations for improvements in mind, feel free to share.
  • Limit multi-user PMs to only accounts who have an specific amount of existing forum engagement (e.g. 20+ posts, keep actual number private and changing)
  • Limit links in PMs to only accounts who have a specific amount of existing forum engagement (e.g. 5+ posts, keep actual number private and changing)
  • Require account setup (e.g. profile picture upload, signature) before access to certain features (e.g. PMs)
  • Automatic flagging and logging of accounts that get errors too often (helps stop people testing bots)
  • Captchas for PMs containing profanity (would help with toxicity too)
  • Disable PM email notifications by default
PLEASE QUOTE ME IF YOU ARE REPLYING TO ME
Desktop Build: Ryzen 7 2700X @ 4.0GHz, AsRock Fatal1ty X370 Professional Gaming, 48GB Corsair DDR4 @ 3000MHz, RX5700 XT 8GB Sapphire Nitro+, Benq XL2730 1440p 144Hz FS
Retro Build: Intel Pentium III @ 500 MHz, Dell Optiplex G1 Full AT Tower, 768MB SDRAM @ 133MHz, Integrated Graphics, Generic 1024x768 60Hz Monitor
6 minutes ago, rcmaehl said:
  • Limit multi-user PMs to only accounts who have an specific amount of existing forum engagement (e.g. 20+ posts)
I had this same idea, it is not viable sadly.  The change required would prevent all existing users from sending PMs until they posted an additional X times.  There is a potential workaround, but we are weary of using that given the risk.  Additionally, this would likely just push the spam into topics and status updates where public visibility is higher.  It would be good that it's less directed at users, but you can see the downside as well hopefully.
Quote
  • Limit links in PMs to only accounts who have a specific amount of existing forum engagement (e.g. 5+ posts)
I'm not sure this is even possible, but if it was, it would fall victim to the above limitation anyway.
Quote
I'm not sure we really want to do this given the amount of collateral damage it could cause, as well as the relatively low barrier to entry for spam accounts.
Quote
Not sure about this one, will mention it to the group
Quote
An additional captcha has been added to the sign-up process for probable spam sources
Quote
This should be easily doable, but would not help anyone with them already enabled.
No, it's more than a few bots, a LOT more.
Our count of spam PMs is in the thousands! Quite a few people worked their ass off to fix that (thx guys!)
But not me though, I was offline fighting my own IRL war ; my daughter didn't want to do her homework !!! :P
Edited by wkdpaul
If you need help with your forum account, please use the Forum Support form !
They seeded the crap out of this site .... I am certain there was there three names with some random numbers just making account after account. So do not comfortable cause there is more. :)  Should be easy to figure out tho ? New account list.
14 minutes ago, Ryan_Vickers said:
-snip-
One additional thing. Various websites use exit pages/scripts. Links to external traffic headed can be filtered and specific domains blacklisted. onbeforeunload or something along those lines
Just now, rcmaehl said:
One additional thing. Various websites use exit pages/scripts. Links to external traffic headed to external websites can be filtered and specific domains blacklisted. onbeforeunload or something along those lines
Without going into too much detail, we are actively filtering spam based on content and have added things to the list to deal with this new issue.  I am not sure I follow... is this what you're describing or something else?
Way ahead of you, we have a list of accounts.
Not sure how they got around the signup captcha, but it happened quickly and it was hundreds of accounts.
As @Ryan_Vickers mentioned, if there are any accounts left, it's because they don't follow the *name+number* scheme and were not reported.
That shit hurt the forum spam reputation since lots of people have email notification enabled, so the forum sent thousands of spam-looking emails (the emails contained the PM content, which was spam) ... So yeah :(
Edited by wkdpaul
Basically, these groups have hoards of human slaves they can submit capchas to for verification.  They just sit around all day doing them for pennies, letting the attackers focus on other aspects of what they're doing (not that they ever seem to put much effort or thought into that either though).
This is more of a retroactive(?) approach for linked content that has bypassed spam filters.
Sites used to display messages like these for external links with onClick, onBeforeUnload, or other implementations:
Image result for external link warning
During this time you can compare the external link to a blacklist in whatever implementation you've created and display an appropriate message. e.g. Navigation to <domain> has been blocked due to known malicious content. OR <domain> appears suspicious, are you sure you wish to continue? While this can easily be bypassed using URL shorteners and really any website with open redirects, it's an extra layer of security while cleanup is being done. It's a bit of work, but spam filters can't catch everything, so additional mitigation options after the spam has been created are always useful.
During this time you can compare the external link to a blacklist in whatever implementation you've created and display an appropriate message. e.g. Navigation to <domain> has been blocked due to known malicious content. OR <domain> appears suspicious, are you sure you wish to continue. While this can easily be bypassed using URL shorteners and really any website with open redirects, it's an extra layer of security while cleanup is being done. It's a bit of work, but spam filters can't catch everything, so additional mitigation options after the spam has been created are always useful.
Ah I see now, yes I've seen those before on other sites.  I'll mention this to the team as well, since it's probably not the worst thing to have anyway, although I'm not sure how much it'll help in this case.
