Which should I use for white build? Cooler Master H500P or Corsair Crystal 570x White
Go to solution Solved by Butt Stallion,
On 1/12/2018 at 11:08 AM, Santo22 said:
Man the Crystal 570x is a beautiful case! Im in a similiar boat, but I'm deciding between the Crystal and the R6. Between the two you picked though, the Crystal gets my vote for sure. Do you know if the Crystal can house a 240mm and 360mm radiator at the same time? Don't mean to derail your thread, but I'm curious to know.
Its got room for a 280mm or 240mm in the top and a 360mm (maybe 420mm if that exists) on the front.
Also /kill thread, I went with the 570x and it's amazing and I managed to perfectly cablemanage it
I'm building my first computer and am really stuck on which case I should get. I love the crystal 570x but all the problems with it make me nervous about buying a $180 case especially since there are usually no rebates on it. Also they don't sell the PSU shroud cover in white which is completely ridiculous and they never have the black one in stock. On the other hand I saw the H500P and really liked it. It's not especially aligned with my white themed build but its gray and could look good with white parts in it. It also is only $130 right now after MIR. It just isnt the square blocky all tempered glass feel that I really like about the 570x. Any help is very much appreciated.
Perhaps take a look at NZXT? They have a wide range of white cases. Personally, I really liked the Manta, H400i, and H200i. They all come in white variants. There is also a z370 mobo from NZXT that is white and customisable with colors. It is 300... but it is probably the most aesthetically pleasing mobo I have seen with a white design. Doesn't look too gamer-y with red accents I guess.
Case: InWin 303 Motherboard: Asus TUF X570-Plus Processor: Ryzen R9-3900x GPU: Gigabyte RTX 3070 Ram: 32 GB DDR4 3000 MHZ
 PSU: Corsair CX750M Storage: 1TB Intel 660p NVME SSD and a 2TB Seagate 7200RPM HDD Mouse: Logitech G600 Keyboard: Razer Blackwidow Ultimate 2014 HeadphonesSteelseries Arctis 7 Audio: Shure PGA58 with a Focusrite Scarlett Solo 3rd Gen
Buy the second case it’s way better and way better looking. And it’s rgb
Between the two I'd go for the 570X. I have the black one and it's a nice case. It has a couple of downsides like the PSU shroud and cable management space on the back, but otherwise it's a fine case.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
The 570x is also rgb
yeah I'm worried since it's white then it'll look like trash with my black psu cables (I'm not rich enough for a RM750x White)
Also I should mention my parts.
MSI GTX 1060 Armor 6gb
MSI B350 Tomahawk Arctic
Ryzen 5 1500x
CX650M
2x8 Gb Corsair Vengeance RGB
NZXT is pretty cool, I'm thinking of upgrading to a kraken sometime in the future but there's too much white going on for my taste. Especially since I have all white components basically. Also they don't really have a 3 tempered glass case. The front of the cases are just plain white which isn't really my favorite look.
yeah I'm worried since it's white then it'll look like trash white my black psu cables (I'm not rich enough for a RM750x White)
Hard to judge from a picture indeed, but I also have the 760T in white, which is quite white-white if you know what I mean. So if it's like that I'd be fine with it.
You pictured the white colored 570X though, not the RGB variant though.
But I wouldn't even consider the H500P personally, just garbage quality case with no airflow at all. The 570X at least has a bit of both.
Just so you know the H500P has kinda shite airflow. I'd go with the crystal
That's an F in the profile pic
Anyways, name aside
H500P? Crap. Garbage. Dont waste your money on it. However the upcoming H500P that has redesigned front and top panels is worth considering, but no word on when that will release. If you need it now, 570X. If you want a third option, Define R6, comes in Black, white, Gun metal gray and Titanium
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
3 minutes ago, TVwazhere said:
Anyways, name aside
Yeah if i were to wait I would get the H500M but I've been sitting and watching for sales for almost a month now so It's just about time I get a case and actually build my pc lol also ^^ ayy you know it
Then I would either get the 570x, or look at the Define R6. Really cant go wrong with either, theyre both good cases, The R6 being better though overall.
The H500P has poor airflow and less-than stellar build quality. If it were me, I would buy the 570X or consider waiting for the H500M to hit shelves.
Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W
Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850
Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB)
alright guess I'm going to go with the 570x. I'm fairly good at cad drawing so I could probably make a psu shroud by myself.
Thanks everybody
Define R6 white tg would be my pick but im guessing you want to see the fans in the front:
Bildresultat för define r6 white tg
Builds:
LRM_EXPORT_20171202_063346.thumb.jpg.10efc0db336d1e70730c54711b93826c.jpg20171203_185246.thumb.jpg.592aa7c348558c9bf8872c79fbace3c6.jpg
24463512_10155850393778428_550358194_o.thumb.jpg.9ce4c5e0b7f81745b26d006c545ce70f.jpg
Love my 570x in white RGB - also was able to get it for 120 on newegg. Has my vote - but if you run SLI - your cards will run warm
SLI 1070 Setup for sale!!!
Here's a post I wrote about a H500P Remake, it's white and has a mesh front panel
The original H500P doesn't have "bad airflow", that's what the sheep say. If you look at the data, it has airflow above average, but it doesn't deliver on the high airflow that was heavily marketed
RGB & Fan control ULTIMATE GUIDE !
crystal 570x
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
 Current System: MoonLightRyzen
CPU: Ryzen 7 1700x @ 3.9ghz  Board: Asus ROG C6H  Ram: G.Skill TridentZ 32gb 3000mhz  Case: Lian Li PC-O11 Dynamic
GPU: Asus ROG Strix GTX 1070 OC in SLI M.2: Samsung 960 Evo 250gb SSD: Samsung 850 Pro 512gb x2 HDD: Seagate Barracuda 3TB and 2TB
PSU: Corsair RM850x White  Cooler: XSPC/Phanteks Custom Loop
Backup System: RedDragonV3.0
FX-8350 @ 4.7ghz, Asus TUF Sabertooth 990fx r3.0, MSI GTX 1060 6gb Gaming X, Crucial Balistix Tracer 32gb, M.2 Samsung 960 Evo 250,
Seagate Firecudda 2tb, Seagate Barracuda 2tb, NZXT S340 Elite White, Kraken X62, Corsair RM750x, Hue+
19 hours ago, Captain Chaos said:
Regarding the Cooler Master ...
Watch the ces coverage on cases,Cooler master did a remake on the h500p they added mesh add ons for the top and front.They fixed the cheaply mounted front and top panels.And even offer it in white.Skip to about 6 mins in
And watch this
Use the H500M white edition when it comes out. DO NOT BUY the regular one it is horrible!
Watercooling Pro & Keyboard Enthusiast!
For a white mid tower the define r6 is best right now,The runner up to me is the lian li alpha 550,I do like the phanteks cases but they lack tempered glass in white and no usb c.If you want a cube case the core x5 and core x9 both come in white.
