Project ITNOS - The Folding@Home Build
ITNOS Definition....
IN THE NAME OF SCIENCE
It's about time I posted one of my own builds instead of just builds I made for other people huh? You'll notice a lot of parts are mismatched; this is because 85% of the system were parts from my old build that I'm re-purposing IN THE NAME OF SCIENCE (hence the name)
Core i5-4570 - $68 on Ebay
Gigabyte GA-Z97X-UD5H (From old main rig)
Team Elite 2x4GB DDR3 1333mhz - $20 on Tech forum
Corsair H90i AIO (From old main rig)
Corsair CX600M (from old main rig)
EVGA 970 FTW (From old main rig) / Asus 750ti - $60 on Tech forum
Thermaltake Level 10 GT (From old main rig)
Asus PCE-AC68 Wifi adapter (The Router is two stories above this, but this wifi card still holds a steady 5 bar signal on 5GHz)
640GB 2.5" HDD from an old laptop Running Windows 7 Ultimate. (It's what I had)
There's not much to say about this build. If you want to learn more about what Folding is, I'll link the LTT post below, but the TL;DR is you donate your hardware to run full time for Stanford University to help research for multiple diseases. Think of it as mining for a cure for cancer.
I had about half of ITNOS still assembled (out of sheer laziness)when it was disassembled when I side-graded to the mITX form factor. This conveniently ended up saving me some time.
(Please ignore the backgrounds I'm building this in a basement :D )
20181109_172022.thumb.jpg.6a4e2c5bddf349aa0b9882f14a34b842.jpg20181109_172336.thumb.jpg.999951708eba1a910506c984b4120ef0.jpg
Some Thermal Paste donated from the thermal paste tube from my Cryorig H7 that's now in my main rig (I once had Arctic MX-4 lying around somewhere but thats lost. Plus this doesnt matter; The CPU isnt super important in this system anyways, even I were to fill in all three GPU slots in this board)
You'll note here the RAM specified in the parts list isnt installed. Thats because the GPU/RAM were ordered together but they wont get here till 11/12, and I didnt want to wait. So I sacrificed an 8GB stick from my main rig (Sorry Computer-I-Dont-Have-A-Name-For) to get ITNOS up and running. As such you wont see any pictures of the Asus 750ti for a while either.
With the GPU and WIFI installed, it's time to see if it would post
BOOM!
Man, if I'm to upgrade two things in this build, it's the HDD and the PSU. The PSU just or potential upgrades/efficiency down the line since this will be running 24/7, but the HDD.... Oh man I totally forgot how bad HDD's used to be using them as an OS. Actually having to use it... It took one hour after boot up to get folding started (Mind you this was technically not a clean copy so that doesnt help but still). Unfortunately I had only ONE keyboard, so every time there was an issue I had to drag my keyboard up and down two flights of stars back to my main rig (I dont know how many times I did that) so I could do things like download Wifi Drivers or figure out which port on my router each system was connected to in IPConfig.
Here's the Final result! 315k PPD isnt what I was expecting from the 970, but I think it has something to do with the fact that the memory doesnt seem to want to go beyond 3004mhz even with a manual OC applied....
I also had a couple of issues with getting my main rig (folding with a 1080ti) to monitor ITNOS remotely, but @Gorgon's guide and a bit of extra pointers got me up and running without much fuss.
I'm also considering trying Linux, but as a first time user that would be a very big learning curve and the downtime for the competition month probably wouldnt yeild me any significant gains. If I do do that,I'll post comparisons here:
https://linustechtips.com/topic/993224-project-itnos-the-foldinghome-build/
15 minutes ago, TVwazhere said:
not enough thermal paste...
Image result for verge thermal paste
Insanity is not the absence of sanity, but the willingness to ignore it for a purpose. Chaos is the result of this choice. I relish in both.
I knew I'd get one of these comments so thats why I posted it :D
Nice! I’m sure most enthusiasts have hardware sitting idle from our constant tinkering so repurposing it for Folding is a great way to pay it forward.
FaH BOINC HfM
Bifrost - 6 GPU Folding Rig  Linux Folding HOWTO Folding Remote Access Folding GPU Profiling ToU Scheduling UPS
Systems:
desktop: Lian-Li O11 Air Mini; Asus ProArt x670e WiFi; Ryzen 9 7950x; EVGA 240 CLC; 2 x 48GB DDR5-6000; 2 x Samsung 980 Pro 500GB PCIe3 NVMe; 2 x 8TB NAS; AMD FirePro W4100; Corsair SFF750
nas1: Fractal Node 804; SuperMicro X10sl7-f; Xeon e3-1231v3; 4 x 8GB DDR3-1666 ECC; 2 x 250GB Samsung EVO Pro SSD; 7 x 4TB Seagate NAS; Corsair HX650i
nas2: Synology DS-123j; 2 x 6TB WD Red Plus NAS
nas3: Synology DS-224+; 2 x 12TB Seagate NAS
dcn01: Fractal Meshify S2; Gigabyte Aorus ax570 Master; Ryzen 9 5900x; Noctua NH-D15; 4 x 16GB DDR4-3200; 512GB NVMe; 2 x Zotac AMP 4070ti; Corsair RM750Mx
dcn02: Fractal Meshify S2; Gigabyte ax570 Pro WiFi; Ryzen 9 3950x; Noctua NH-D15; 2 x 16GB DDR4-3200; 128GB NVMe; 2 x Zotac AMP 4070ti; Corsair RM750x
dcn03: Fractal Pop Silent XL; Gigabyte Aorus z370 Gaming 5; i9-9900k; BeQuiet! PureRock 2 Black; 2 x 8GB DDR4-2400; 128GB SATA m.2; MSI 4070 Ti Super Gaming X; MSI 4070 Ti Super Ventus 2; Corsair RM750e
dcn04: Fractal Meshify C; Gigabyte Aorus ax570 Master; Ryzen 9 5950x; BeQuiet! PureRock 2; 2 x 16GB DDR4-3200; 250GB NVMe; Asus RTX 4070 Dual OC; MSI 4070 Ti Super Ventus 2; Corsair TX650m
dcn05: Fractal Define S; Gigabyte Aorus b450m; Ryzen 7 2700; AMD Wraith; 2 x 8GB DDR 4-3200; 128GB SATA NVMe; Gigabyte Gaming RTX 4080 Super; Corsair TX750m
dcn06: Fractal Focus G Mini; Gigabyte Aorus b450m; Ryzen 7 2700; AMD Wraith; 2 x 8GB DDR 4-3200; 128GB SSD; Gigabyte Gaming RTX 4080 Super; Corsair CX650m
Should have delidded the 4570 for a laugh.
Lots of science going on there though
8 hours ago, TVwazhere said:
Couldn't help but notice that you applied all 4 screws to your CPU cooler. This is incredibly dangerous as it can lead to too much pressure being applied to your CPU. Best practise is to leave one screw off to ensure it works properly. I saw it in a build guide video I watched...
/sarcasm
  • 2 weeks later...
Project ITNOS is now at full speed thanks to the care package that (finally, after a week delay) came in today.
760ti and 8gb of ram. Nothing flashy, but got a good bundle deal on them when I needed ram. Now my main system can go back to having a full fat 16Gb! Woo!
These silver Team Elite sticks look better in the gray RAM slots anyways
I ironically had to use a dual molex to 6pin adapter to get the 750ti up and running but it was worth it. If I get anything more powerful than this though I'll definitely need a PSU upgrade
Ah, F@H is doing some more billshittery again, not realizing that 750ti isn't capable of 970 PPD figures... At least the main client remotely monitoring the system gives me a more accurate 400ish PPD. The 970 definitely runs a bit warmer now with the 750ti there but it's still under 60°C so I can't ask for much more than that!
  • 2 weeks later...
Now that the folding month is over, I decided to try and undervolt (well, underclock actually) ITNOS.
MSI afterburner would not allow undervolting in its slider, the minimum voltage applicable was 0. So the only way to reduce voltage was to reduce GPU power, which the 970 was using 90% of (even though it was set to 110 I believe) and the 750ti was only using about 65%, incredibly low power usage.
The 970 went from 1485mhz @1.212V to roughly 1300mhz @1.030V. I'm no electrician, but I'm pretty sure that's a lot. Sadly I dont have a total power draw meter on the system so I'm not sure how much this change actual made to the total power consumed by the system.
My 750ti couldn't actually go any lower than 77% Power, so I just kept bumping the core speed up till I was hitting power limit, which ended up almost 200mhz overclock. Damn!
I'm not entirely sure off the top of my head what the original voltage was, but I believe it was the same as it is now. But the core speed is about +135 from what it was previously so now the 750ti should be pulling more of it's weight
So what does this mean? In theory, the 970 Should perform less but consume even less power than the % difference in performance would seem to suggest. Meanwhile the 750ti should perform better while using the same amount of power (which means I could have been using that this whole three months without an electricity hit). In all honestly it would have maybe made a 50k different in three weeks, which would have done nothing for my Folding competition standings.
  • 3 weeks later...
Remember to clean your dust filters!
  • 3 months later...
On 12/18/2018 at 1:55 PM, DVA said:
My Meshify-C hasn't been cleaned in a while, thanks for the reminder.
Quarter annual reminder to clean your dust filters!
  • 1 month later...
On 5/6/2019 at 8:20 AM, TopHatProductions115 said:
I want to get a case like that one day, just to see what it's like to build in...
The Level 10 GT is quite different, mostly due to the hard drive mounting. I've seen very few cases like it, but at roughly $100 on ebay they've hardly stood the test of time when it comes to $175 average priced build quality, aesthetics and standout features. Though I guess "RBG" fans (yes RBG) were sorta standout even though you ONLY got red, green or blue (or a mix those colors) Water cooling is limited to a 120/140mm rad in the back, or removing one of the glorious 200mm fans from the top and sticking a 240 rad up there. Also proper support for a full sized E-ATX motherboard, six total USB ports at the front, good dust filters were great bonuses back in the day, but are now either very common or no longer a big requirement. I'll keep mine for a while, especially now that I have a secondary use for it.
  • 1 month later...
So last week I purchased a Kill-a-Watt meter to help track how much ITNOS costs me per month on my electric bill. It's a fairly simple setup, just plug it into an outlet, plug your device in, set the electric bill rate (I had to calculate mine based on last months electric bill total divided by killawatt hours) and let it sit for a while. After 48-72 hours I landed at around $7.25/month (you can see by day, week, month and year)
There are two things I dislike about this. The first is you'll notice this isnt plugged directly into the wall. This is because the body of the unit sits too low on the outlet, so when you plug the Kill-a-Watt into an outlet, it blocks the lower port from being used (I'm using that for my monitor) so I used a short grounded extension cord with opposing outlets on either side. The other thing is while it has other options to show you how much energy you've used over time and showing you real time Voltage usage (which basically sits at 120v the whole time) it doesn't show you real time wattage usage which honestly was what I was most curious about, mainly because I'm running a bronze efficient power supply and I was wondering if upgrading to a gold or platinum PSU would save me anything substancial in power usage since it's running 24/7.
Beyond that it's a good purchase, and we will most likely use it around the house to see how much certain appliances are using (for example the really old refrigerator in the garage that's 35+ years old (but still works great and refuses to die) We dont really use it for much anymore so unplugging it wont hurt us and might help us as far as power savings go.
sounds really low to me... my server uses approx 55W/h, and for 24/7 usage for a month would come out to 55x24x30(average month of 30 days) = 39,600W. So round up to 40 and x your unit rate, mine comes out at 40x13.6p = £5.44 per month just for a low usage server.
[edit] Actually, the 55W is for the server + router and switches attached to my UPS.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
The 970 and 750ti are heavily under-clocked to draw very little power, so I'm happy to see that it's low.
Ahh cool, that's a very good result then :)
I updated my post above BTW, my 55W was actually for a combination usage of my server + router and switches on average.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Quick update. Unit does indeed show real time wattage pulled from the wall, just had to use the up/down buttons to find it. 240-242W. Much happier with my purchase now that I figured it out.
23 minutes ago, TVwazhere said:
240-242W.
I do that idle with my PC kek.
Well the June Folding sprint started as of midnight last night
As such I've removed the power limits on the 970 and the 750ti, though I dont expect to see a big improvement in performance (especially the 750ti) probably a 35-50k improvement (running about 365kPPD the last six months) but what is notable is I'm now drawing 50w more than before, hovering around 290-294w of actual usage. That's about a 22% power increase for an estimated 10-15% performance increase.
  • 2 months later...
Interestingly enough, now the Top card is boosting to 1975, and the bottom card is only in the 1600mhz range..... Definitely need to look into enabling P0 states for both cards when I get back from work
  • 1 month later...
So some updates after the Folding Month 2019:
For the duration of the Folding Month I ran the cards at full power with +100mhz offsets, which actually allowed both cards to run 2025mhz. I believe temps were in the mid 60's too which is pretty good. Power usage was in the 350w range (need to confirm this when I get home) when both cards were drawing full power, now they're back down to about 280w. Both cards are also now around the same boost clocks in the 1900mhz range while being power limited to 60%
  • 1 year later...
The EVGA FTW2 has been transferred to the Velka 5 build log, so I'm down to a single 1070ti which still pumps put 1.4m PPD at 60% power limit
