Pc cases for best airflow?
SSGSS
What are some of the best cases for airlfow, i see corsair 5000d and nzxt h7 flow being good choices
Yeah, also
Fractal Torrent
Lian Li Lancool 216 and Lancool III
Phanteks G360 and G500
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
Lancool III is massive and heavy, keep that in mind. As good as it is, thing is a tank. I can barely get it up to give the damn thing a vacuum.
how much can a pc case with a good airflow lower the temps of the gpu and cpu, is there videos or data on that? Thanks.
Fractal north with mesh side is probably the best air flow case. but other case could get close to that. a tech bench would probably beat the Fractal north
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
Quite a bit, depending on the differences in case design.
GN has data (based on a consistent thermal testing setup with an air cooler and GPU) on bad and good airflow cases and how that affects temps... From their 2022 roundup:
That's a 15 degree above ambient swing!
Compare the LianLi Lancool 216:
to the Fractal Design North:
to the Abkoncore Ramesses 780:
and finally a $70 Montech case:
I'd love to see LTT and GN team up to do a super scientific case and thermals exploration...
Any case can be an airflow case of you have fans that are strong enough 😄
But I do like my Torrent Compact, if I were to do it again I would get the full sized version.
AMD R7 5800X3D | Thermalright Aqua Elite 360, 3x TL-B12, 2x TL-K12
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X
Seasonic Vertex GX-1000 | Fractal Torrent Compact, 2x TL-B14
