So I tried to get a PC built from iBuyPower for almost $4k. It goes delayed for 2 months and when they sent it to me the cable management could have started a fire and the motherboard was damaged. Asking if the One The ONLY LTT peeps build PCs yet? after looking at how well they build PCs on vids Im more confident in them than companies atm lol.
https://linustechtips.com/topic/1238708-does-ltt-build-pcs-yet/
They don't have the man power to be in the PC building business. Their delays would probably be upwards to a year.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1238708-does-ltt-build-pcs-yet/#findComment-13957893
Linus Media Group is just that, a media group. They don't have the resources to also be a boutique PC shop, or the interest. Imagine, fielding customer support and also product orders and also dealing with this pandemic all at once out of nowhere.
Their PC building guides are pretty suitable to replace any boutique PC shops though, perhaps DIY will be your next avenue?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1238708-does-ltt-build-pcs-yet/#findComment-13957895
Also Linus himself said there isn't much in terms of margins to be made as a system integrator. And he worked as a product manager at NCIX, a local computer retailer here in Metro Vancouver so he would know the amount of money they were generating from NCIX PCs. Or lack thereof.
Plus it's not just about the cost of components and labor to build it, you have the time spent validating systems for stability because they have to warranty these systems. If you have two components that don't work 100% well together, they have to catch that before they get RMA requests for every unit sold. All that money, time, and effort spent means there isn't much left over in terms of profit.
https://linustechtips.com/topic/1238708-does-ltt-build-pcs-yet/#findComment-13957906
Is that picture through a case window?
If it's the inside and there's no case window, I can see it passing an inspection like that, given they're behind. More a matter of it works, passes whatever tests they have, and having no obvious issues.
If that picture is through a case window, then that's pretty sad. With their backlog of orders, I imagine they're trying to get through as much as they can get the revenue in and avoid refunds/cancellations. Not a great look though.
https://linustechtips.com/topic/1238708-does-ltt-build-pcs-yet/#findComment-13958175
Its with the windows on. Tho the wires actually come out of the case cause there is no management for it. And through the front. Also something I didnt put was that there was a broken clip on the motherboard Im going to guess they broke it when assembling it so quickly. Which should have been addressed instead of sending it like that. And they stuffed it around the PSU which can be dangerously hot for both the PSU and wires. Quality over Quantity.
https://linustechtips.com/topic/1238708-does-ltt-build-pcs-yet/#findComment-13958192
The good ol' tuck and stuff method. Definitely not advisable, especially if they're shipping systems like that, since most of that will be dislodged in transport. Properly routing and zip tying obviously takes more time, so they skipped it, but that's a bad end result for a customer.
https://linustechtips.com/topic/1238708-does-ltt-build-pcs-yet/#findComment-13958202
7 minutes ago, LinusTech said:
We have no interest in the PC building business at this time. For the reason, see: https://netcapital.com/files/79756669-2bc2-454d-b4a5-c11022f14b6f/otherfinancial.pdf
Makes sense. Steep profit loss in that one year.
:beard_rubbing_ensues: 🤔
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1238708-does-ltt-build-pcs-yet/#findComment-13958294
Even in 2016... $300k net profit on $8M of revenue???
That's less than 4% net profit
Like, what?
https://linustechtips.com/topic/1238708-does-ltt-build-pcs-yet/#findComment-13958301
On 8/26/2020 at 2:42 AM, LinusTech said:
Like, what?
Yeah but recently, haven't you build a PC for a customer (https://www.youtube.com/watch?v=TCMKqA3lCJg&t=769s)? Was that for a youtuber or a one off? Would be quite interesting to know since the 'Customer' wasn't disclosed in the video
A guy asking and answering in his bedroom since he has nothing else to do
https://linustechtips.com/topic/1238708-does-ltt-build-pcs-yet/#findComment-13973898
It will be disclosed later :)
https://linustechtips.com/topic/1238708-does-ltt-build-pcs-yet/#findComment-13974766
:turnip:
xD
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1238708-does-ltt-build-pcs-yet/#findComment-13975221
I think they would have to build up to it. Like how artists take commissions, just start with "We are going to build X PC's this month, but only if you're going to buy them." And when it gets to a point where the pre-orders are regularly filled as fast as they are made available, then you move on to making them in advance.
Though if I were doing it, I'd probably only build edge-case systems that use the current/best parts on a "manufacturer warranty only" basis, because if you're just looking for a cheap PC, you are better off buying one from Dell or HP, at least you have their warranty system.
Though, IMO, getting brand labeling for LTT parts might be an easier first step. Parts like cable management straps.
https://linustechtips.com/topic/1238708-does-ltt-build-pcs-yet/#findComment-13975993
he got linus to reply. jeez
https://www.lttstore.com/
1990 M3s are the best looking things ever made.
^This statement has been retracted^
2020/2021 BMW S1000RRs/Ninja H2s are the best looking things ever made.
Don't ask to ask.
If you want me to see the reply, @XGoodGuyFitz(aka me) and/or quote me.
Thanks!
https://linustechtips.com/topic/1238708-does-ltt-build-pcs-yet/#findComment-13976253
they have cable management straps, dont they?
Don't ask to ask.
Thanks!
https://linustechtips.com/topic/1238708-does-ltt-build-pcs-yet/#findComment-13976257
Video idea.
“INCOMPATIBILITY?
PART 1: SEE WHAT DOESN’T WORK IN YOUR COMPUTER!”
then a picture of Linus holding a screw driver with the cross out symbol like it can’t be fixed & a sad face and empty wallet.
https://linustechtips.com/topic/1238708-does-ltt-build-pcs-yet/#findComment-13977893
