will xbox 2 be at 2080 ti level?
Dehaka
they said its 4 TIMES FASTER THAN X1X. x1x is around 1070 performance, so 4 times that is 2x 2080 ti performance, which i highly doubt. but will it at least be on par with 1 2080 ti for $499?
Marketing fluff. If they pull off 2080 ti perf I'd literally be amazed, but that's totally unprecedented and unrealistic.
Primary PC:
Especially if Microsoft wants to keep a lower price.
How? I mean it's sort of close in FP32, but that's not directly related to gaming performance.
No way. If that's the case Radeon Technologies Group (RTG) won't struggle against Nvidia with Vega and Navi at all.
Desktop benching:
X1X is closer to a 580.
It's marketing nonsense. There's no Navi chip out right now that's remotely close to the 2080 Ti. Only the 2070.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Did they specifically say what is 4 times faster? Because I don't recall them saying the GPU is specifically 4 times faster. It could be the CPU alone is 4 times faster. It could be they benchmarked the entire system and the score came out to be 4 times higher. Or they could do something stupid like say the bandwidth of storage or memory is 4 times faster.
So unless they said only the GPU was 4 times faster, there's nothing to go off of.
EDIT: Okay, found the offending comment:
They said "from a pure processing perspective", which is very vague. At best it's just the performance difference from data in vs. data out, which would be for the entire system, not specifically the GPU.
EDIT 2: This is also the same video where they said "an SSD and solid state drive" and claims that the GPU has hardware accelerated ray tracing which as far as we know is not on Navi. I mean, maybe the consoles have a special version that has hardware accelerated RT on it, or they consider running RT on the GPU itself hardware accelerated regardless if it runs on the compute cores or a dedicated RT accelerator.
Either way, marketing clearly wrote the script here.
Edited by Mira Yurizaki
What on earth are you smoking? The Xbox One X's GPU is between a RX 580 and a GTX 980:
https://www.techpowerup.com/gpu-specs/xbox-one-x-gpu.c2977
Again what the hell are you smoking xD A single 2080 TI MSRPs for $1,200. AMD hasn't even DISCUSSED having a GPU that can go toe to toe with the 2080 Ti, the highest they have is the Radeon VII which is on 2080 levels. Even their newest arch, Navi, is only at 2070 levels of performance. Do you really think that AMD would ship a console part that has an even better GPU without also creating a comparable dedicated GPU for the PC market??? Use your brain bro...
Not even close.
The next gen of Consoles will likely stay within the $400-600 range, so they'd be lucky to be maybe 2070 levels, if that.
It's around 1060 performance. And absolutely not. I'm sure they just found one thing it's 4x better at, and used that to make the technically accurate statement that it's 4x more powerful.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
The Xbox One X is using an RX 580 (+4 CUs). Last I checked, the GTX 1070 beats the RX 580.
The next-gen Xbox is using Navi, which if Microsoft wants to stay within a price range consumers would tolerate a box under their TV at, is probably cut-down from desktop Navi. and closer to RTX 2060 performance, but we don't know yet.
if you have to insist you think for yourself, i'm not going to believe you.
8 minutes ago, Mira Yurizaki said:
Okay, another theory: 8K is 4 times the resolution of 4K. Hence "4 times the processing power." ?
4 times the power from the display output lol. I wonder if they are all ricers who thinks having a bigger exhaust pipe means significantly more power
Desktop benching:
The sucker is still 18 months away, who knows what they pul off by then
Exactly my thoughts. Simply no way it will be at 2080ti level. probably not even 2080 level. The GPU is not the only component in a console, lets say it costs $300/500 for the entire consoles cost just on the GPU (which it definetly doesn't, this is a very high estimate), a 2080ti is like $1200. Thats a minimum 400% price to performance increase in 18 months and AMD doesn't even have a GPU that can compete with a 2080ti in the first place nevermind making one thats 400% cheaper. And its not like they can finish the GPU design in 18 months, the GPU/CPU of that system is probably already designed and done and the product ships then. No way.
Gaming - Ryzen 5800X3D | 64GB 3200mhz  MSI 6900 XT Mini-ITX SFF Build
Home Server (Unraid OS) - Ryzen 2700x | 48GB 3200mhz |  EVGA 1060 6GB | 6TB SSD Cache [3x2TB] 66TB HDD [11x6TB]
People still don't understand how consoles work... You can't just compare raw HW specs and call it a day. It was similar on PC for a short while. Anyone who owned S3 graphics card around 1999-2000 knows what I mean. I had crappy S3 Savage3D 8MB and I could run almost any Unreal based game at 1024x768 with all settings maxed out. But only when using S3 Metal API. With D3D and OGL it was far worse experience and required RivaTNT2 or Voodoo 3 at the time. It's a similar thing with consoles. There is just ONE hardware configuration and games are super optimized for that hardware configuration.
The main reason consoles started struggling was memory since they ran most of stuff from optical disc and had to preload it before it was needed. And because of pricing of consoles, they never had tons of RAM. That is changing slightly as engines are more optimized to stream resources as they are needed through actual game levels and better utilize what they have available. And if they could do a lot with low to mid end hardwrae in terms of PC specs, new Xbox for example is much better equiped with much newer HW than usual. I just wonder what the price will be because of this...
sorry I have totall lost track on xbox naming, xbox 2 will how many gens later?
41 minutes ago, anuragassingh said:
<a href="https://www.getmodapps.com/2019/06/snaptube-mod-apk.html" rel="nofollow">Snaptube Mod Apk</a>
Nice spammity spam. And @manchild no, the Xbox Project Scarlet won't live up to the performance hype Microsoft is advertising it at - in fact, I'd be surprised if we don't start seeing class action lawsuits against game console manufacturers claiming their consoles run at 8K 120Hz, considering PC's can't do that yet.
Desktop: KiRaShi-Intel-2022 (i5-12600K, RTX2060) Mobile: OnePlus 5T | Koodo - 75GB Data + Data Rollover for $45/month
Laptop: Dell XPS 15 9560 (the real 15" MacBook Pro that Apple didn't make) Tablet: iPad Mini 5 | Lenovo IdeaPad Duet 10.1
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 | Panasonic TS20D Music: Spotify Premium (CIRCA '08)
It would be nice. If I remember correctly, the Xbox 360 was technically better than PC GPUs on release, but it was super rushed to market.
Not even close..
http://www.logicalincrements.com/articles/graphicscardcomparison
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
I seriously doubt their claims, its just too much to cover in so little time it just doesn't seem possible.
I think its just vaporware right now, much like the Mad Box console teased some time ago by Slightly Mad Studios which had pretty similar claims but nothing to back it up.
https://www.cnet.com/news/mad-box-game-console-promises-to-be-most-powerful-ever/
Project Diesel 5.0: Motherboard: ASRock Fatal1ty X370 Professional Gaming /// CPU: Ryzen 5 3600X  /// CPU Cooler: Scythe Ninja 5 /// GPU: Zotac AMP Extreme RTX 2070 /// RAM: 2x 16gb G.Skill Ripjaws V @3200mhz /// Chassis: Lian Li Lancool One Digital (black) /// PSU: Super Flower Leadex III 750w /// Storage: Inland Premium 1TB NVME + Toshiba X300 4TB
Peripherals: Mice: Cooler Master MM720 /// Keyboard: Corsair K70 MK2 SE (Cherry Silver), Blitzwolf BW-KB1 (Gateron Reds) /// Monitor: Acer XZ320Q 32' (VA, 1080p @240hz) /// AMP: Topping PA3 (Onkyo Integra A-817XD undergoing restoration) /// DAC: Weiliang SU5 /// Speakers: AAT BSF-100 /// Mike: Alctron CS35U /// Headphones: Blon B8, ISK MDH-9000
Living room: TV: Samsung QLED Q7FN 55' 4k /// Amplifier: Denon AVR-X2400H /// Speakers: DALI Zensor 7 /// Consoles: Sony PS4 Pro 1TB, Sony PS3 500gb /// LD/CD/DVD: Pioneer DVL-909 /// Power Supplies: Upsai ACF-2100T + GR Savage CDR2200EX
Uhh you can when they're saying that a console is equivalent to x GPU...
Is there optimization? Of course. Usually for consoles, however, optimization usually means decreasing the quality so things like LOD, texture quality, etc which is why you can't change graphics settings on consoles as it's locked in to what provides the best playable experience on the console.
You don't have settings on consoles because that would defeat the purpose. The purpose of consoles is that games just work and are exactly as intended by developer without any fiddling and tweaking. And that is only when game is designed for PC and then for console.
