Dual CPU cable
Go to solution Solved by ImWilly,
Dual CPU power plug is usually used for overclocking the CPU, most notably for high end Intel CPU
PSU manufacturer does that more often as a way to reduce cost for cables instead of providing 2 separated cables
If you don't use Intel high end CPU, you can just plug one of connector to the motherboard, just make sure to see the labels on the cable so that you won't plug the connector the other way around
It does no harm to plug both Dual CPU connector to the motherboard as well, at least less cable hanging on your rig
So i got a aerocool inverter 750 80gold and it has a cpu cable as 8 pin to dual 8 pin. Since this my first time building a pc i dont know how to connect them. do i connect the dual 8 pin side to motherboard 8+8 pin cpu power part? it makes me confused bc my psu doesnt have 2 seperate 8 pin for cpu but motherboard has two 8 pin for cpu power. Rn i only connected one of that dual 8 pin side to motherboard cpu power pins. Cable is shown in image . Sorry if its a dumb question
https://linustechtips.com/topic/1568292-dual-cpu-cable/
My System: Ryzen 7800X3D // Gigabyte B650 AORUS ELITE AX // 32GB 6000MHz DDR5 Silicon Power Zenith CL30 // Sapphire Pulse AMD Radeon RX 7900 XT OC with mod heatsink on the metal plate  // Phanteks P300A  // Gigabyte Aorus GEN4 7300 PCIE 4.0 NVME // Kingston NV2 Gen4 PCIE 4.0 NVME //
Seasonic Focus GX-850 Fully Modular // Thermalright Frost Spirit 140 Black V3 // Phanteks M25 140mm // Display: Bezel 32MD845 V2 QHD // Keychron K8 Pro (Mod: Gateron black box ink; Tape mode on PCB and Keycaps) // Razer Cobra Wired Mouse // Audio Technica M50X Headphone // Sennheiser HD 650 // Genius SP-HF180 USB Speaker //
And Laptop Acer Nitro 5 AN515-45 for mobility
Phone:
iPhone 11 (with battery replaced instead of buying new phone for long term and not submitting (fully) to Apple Lord
https://linustechtips.com/topic/1568292-dual-cpu-cable/#findComment-16392555
doesnt matter since theyre daisy chained
besides you dont need a dual 8 pin since a single eps can probs handle 500w+ no issue judging by all those old x58 era hwbot subs on boards like the rampage ii, just some stupid marketing nonsense with boards that have useless dual 8 pins on consumer hardware
for hedt stuff like threadripper definitely needed since those things draw a ton of power but you probably wouldnt be buying a <1000w unit for those
https://linustechtips.com/topic/1568292-dual-cpu-cable/#findComment-16392572
  • 3 weeks later...
