I've seen a number of build requests here for Ryzen system, the vast majority are for that matter. All good, Ryzen is apparently the king of the hill right now, but I see a lot of near-identical builds for that matter as well (Ryzen, nVidia 20xx GPU, RGB out the ears, etc) but of course one size does not fit all, so, in your opinion, what sets your system apart from the next guy?
I'll start:
Dual Xeons
No RGB
Workstation GFX card (Amd Radeon Pro WX 7100)
4 NAS systems
4 internal drives on a SAS controller
5 m.2 drives on a PCIe controller
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1297649-what-sets-your-system-apart/
Very minimal RGB. Only the Raedon label on my GPU which you can't really see. Keyboard and mouse.
Non tempered glass side panel.
(Largish)ITX with full size GPU.
5800x and 6800 XT From AMD and not scalpers.
It's kind of a multitool of computers. Lots of screen space, ADIA64 panel if you want to know EVERYTHING it's doing. Editing/streaming capable. Audiophiles won't puke listening to it(Schiit stack and Massdrop Sennheiser 6xx).
RetroPi and Switch hooked up to capture card for playing when nothing else piques my interest.
As noted in the Battlestations thread. There's an Austrian made "airsoft" nearby always.
20201224_120803.jpg?width=457&height=609
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
The amount of dust...
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
The one bit of hardware that I think makes my PC fairly unique is the fact it has an I²S PCIe card in it for connecting to one of my DAC's, other than that it's a fairly average high-end rig.
It also drives a home theater that is much more expensive than it. Which I think is fairly rare.
Good lad.
LTT's Resident Porsche fanboy and nutjob Audiophile.
Main speaker setup is now;
Mini DSP SHD Studio -> 2x Mola Mola Tambaqui DAC's (fed by AES/EBU, one feeds the left sub and main, the other feeds the right side) -> 2x Neumann KH420 + 2x Neumann KH870
(Having a totally seperate DAC for each channel is game changing for sound quality)
Good lad.
It's probably not up to your specs though 😉 I want to step up, but just not quite there yet. The Magni, Modi and Loki are all too new so other projects have to come first.
Project Hot Box
Oppbevaring
Hey, you have HD6xx' which are damn near endgame for alot of audiophiles. It's far from a "gaming" headset lol.
They're a HUGE step up from from a Razer Kraken. I love them. There's just some...fine tuning... I need to get adjusted. Old lady gets spooked in a game while were in a call and it turns into a shrieking pain sound. Which, the majority of that is on her set up, but I can't get her to go to a full audio set up. I mitigated that mostly by turning windows way down. I'm sure there's just some simple settings on my end I still need to get going.
This is from 2 pc cases ago. Went from this to ITX i9 to ITX 5800x
Project Hot Box
Oppbevaring
  Reveal hidden contents
If you're willing to install some stuff, EqualizerAPO with a compression VST plugin would cut down on excessively loud noises. Compression just makes everything have a similar volume.
23 minutes ago, Grabhanem said:
The pure pointlessness of the config.
That's mine as well, I'm building the best Ivy Bridge Xeon build I can, my mobo can support 3/4 of a terabyte of RAM, and I"m seriously considering that, just because I could...
It's one of the only AMD systems on the forum that's not Ryzen... and is probably the complete opposite of what Ryzen is today in terms of relative performance on the market.
I guess that's what happens when you ask the forum for build suggestions. It's like going to a car forum and ask how you should modify your car. You're just going to get the same few suggestions over and over again. Do anything that's outside of those suggestions and you'll be laughed at essentially. I've seen people berated for going for Intel builds these days.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
The sheer mass of hardware (from multiple generations) I have inside my case.
I've got a Ryzen 5 3600, a Thermaltake SpinQ++, 16GB DDR4-3200 CL14, and 2 GTX 650 Ti Boosts (separate).
I've also got dual optical drives, a floppy drive, a Zip drive, 4 hard drives (80GB, 250GB, 2TB, 3TB), 2 SSDs (128GB boot, 16GB Optane), and a lot of cables.
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
Now is that floppy and Zip drive actually functional? How many PCI (not PCIe, old school PCI) cards did you have to use to get all of that to work?
Yep, they are.
And I have all PCIe cards because my B350 board doesn't have PCI.
I've got a PCIe 2.0 x1 card between my 2 GPUs with 1 IDE and 2 SATA, giving me 6 SATA ports.
This is just enough for my 6 SATA devices (4 HDD, 1 SSD, 1 Blu-Ray) and my 2 IDE devices (1 optical, 1 Zip).
My floppy drive runs off of one of those floppy-to-USB converters.
EDIT:
The only two things nonfunctional in my case are the 25-pin serial port (I have a 9-pin plugged in) and my front eSATA port.
4 minutes ago, ragnarok0273 said:
Yep, they are.
EDIT:
I don't even want to imagine what that cable management is gonna be like hahahaa
There is none.
My case has no room for it.
My cables are between my PSU and HDDs (towards the bottom of the case), then run across my GPUs and up towards the top, splitting off as they go.
My EPS cable goes on the opposite side, across my rear fan, and then my floppy/USB cable cuts straight across to the back.
Just now, ragnarok0273 said:
There is none.
I hate to say this, but I'm curious now...
Project Hot Box
Oppbevaring
We might have to move that to the tech horrors thread
