Working on build, AM4 or AM5 or Intel? Please help
4 hours ago, Hi P said:If I recall correctly Photoshop can be GPU accelerated, what if it doesn't run well on integrated graphics?
It can be GPU accelerated, but it much prefers Intel iGPUs for that. For just learning though, either are probably fine.聽
聽
4 hours ago, Hi P said:AM5 - Ryzen 8XXXG - No GPU
- He would be on current gen and looks like the integrated graphics are more than enough for what he does
- Even if the budget is not a problem, I wonder if it's money well spent or not
- I've seen videos giving a bad review to Ryzen 8000 APUs
I will say the main reason you see the APUs getting bad reviews is because they're generally a bad value, not because they're bad chips. They make sense for a handful of situations, but a lot of the time you're better off getting a lower end CPU and a cheap GPU instead of one of these (RX 580 and R5 7500F would be a good combo for instance, and not too much more than an 8600G and a good kit of RAM). If you're really worried about power consumption, they make more sense.聽
聽
聽
Personally, I'd go for an Intel setup here, mostly because the Intel iGPU works a lot better for Adobe stuff, it's still good enough to play LoL, and it's got a bit better upgrade path than AM4 does. Something like this would be a decent option:
