2 minutes ago, silencer12 said:
Either you install them with what came with the adapter or you use a second computer to download them. Put on a thumb-drive. Extract and install on the first computer.
Im kinda stupid r u talking about the motherboard?
https://linustechtips.com/topic/1568273-internet-problem/#findComment-16392528
10 minutes ago, silencer12 said:
Your Wi-Fi adapter.  Is it built-in to the motherboard?    Your antenna was connected to it.
Then you have the motherboard disc with the drivers on it.
Its built in to the motherboard. And what should I do wth the disc
https://linustechtips.com/topic/1568273-internet-problem/#findComment-16392546
Your pictures are saying you have no Wireless Adapter installed
Please take a picture of Device Manager open with Network Adapters expanded and showing.
If there is a yellow mark next to WiFi then you need to install the driver.
If there are no Yellow marks. go to search and type ncpa.cpl and press Enter.
This will list all network adapters. If there is no Wifi adapter, then you do not have a Wifi adapter plugged in.
If there is one,. right click it and choose Status.
Please click the "Thumbs Up" on any volunteer's post to thank them if they helped .(lower left, just to the right of My Computer )
https://linustechtips.com/topic/1568273-internet-problem/#findComment-16393351
