How to double the speeds with two Ethernet cables?
Solved by Alex Atkin UK,
3 hours ago, Razzee said:PC1 can access PC2, PC2 cannot access PC1 at all (via Network or Crossover).
It simply says that "O Windows não pode localizar \\192.168.0.17. Verifique a ortografia e tente novamente".
"Windows cannot locate (IP or PC name)" Check the ortography and try again."
If I type the name of the PC (Zweitestock), it cannot be found either. I have set all permissions (folder) to "Everyone".
Probably unrelated, but don't set a gateway on a network that doesn't HAVE a gateway (router) such as when using a cable between two PCs.
Make sure on PC1 the firewall is set to Private or turned off for that network, that's usual reason for not being able to connect to it.
