I Was Putting Pretty Stickers On My Case Until...
Solved by SpookyCitrus,
Yes as the others have said those stickers are for the CMOS battery, usually come with ASUS or Gigabyte motherboards where the battery is in a visible location. Just makes it look more aesthetically pleasing. Especially if you have a specific color scheme and the silver of the battery doesn't match it, but then again the stickers are usually a set color anyway or the CMOS is behind the graphics card, so in most cases they are pointless.
