Need help, tftp to switch
Kina new to this and I've been working on getting my Brocade 6610s setup for my deployment. I got the setup started and the Tftp server running on my pc and every time I tell it to pull the config files it just times out. I see the connection start on the tftp server but then time out.
I have changed cables, disabled my firewall and even now directly connected using an auxiliary ethernet port I have.
Connection received from 192.168.1.50 on port 1027 \[25/04 22:20:52.540\]
Read request for file <grz10100.bin>. Mode octet \[25/04 22:20:52.540\]
Using local port 57235 \[25/04 22:20:52.540\]
Connection received from 192.168.1.50 on port 1027 \[25/04 22:20:56.081\]
Read request for file <grz10100.bin>. Mode octet \[25/04 22:20:56.081\]
Using local port 57236 \[25/04 22:20:56.081\]
Connection received from 192.168.1.50 on port 1027 \[25/04 22:21:00.081\]
Read request for file <grz10100.bin>. Mode octet \[25/04 22:21:00.081\]
Using local port 63110 \[25/04 22:21:00.081\]
Connection received from 192.168.1.50 on port 1027 \[25/04 22:21:04.081\]
Read request for file <grz10100.bin>. Mode octet \[25/04 22:21:04.081\]
Using local port 64706 \[25/04 22:21:04.081\]
TIMEOUT waiting for Ack block #1 \[25/04 22:22:20.601\]
TIMEOUT waiting for Ack block #1 \[25/04 22:22:24.154\]
TIMEOUT waiting for Ack block #1 \[25/04 22:22:28.142\]
TIMEOUT waiting for Ack block #1 \[25/04 22:22:32.160\]
Project Casper - Glass Tubing Build
Ryzen 9 5905x     |    Gigabyte Aorus Extreme X570    |   Strix 3090
GSkill 64gb 4000mhz   |    EVGA 1600T psu     |      3x Samsung 980 Pro NVME 1tb Raid 0
  4 x Crucial MX500 2tb raid 0   |    Glass Hard Line Tubing  - EKWB Blocks
https://linustechtips.com/topic/1568147-help-needed-switch-tftp/
6 hours ago, OddOod said:
Factory reset the switch and start fresh?
Also, this looks like a typo
The switch is factory doesn't even have a config file which is what I'm trying to upload to it
From what I see, the switch is trying to get some kind of binary file, not necessarily a config file ( e.g. the .bin extension ) .
This reminded me from this site where there is some TFTPD suggestion for Windows :
https://fohdeesha.com/docs/brocade-overview.html#setting-up-tftp-windows
So here are some question that may point you the right way :
  • what TFTPD are you using ?
  • Is the firewall disabled (if you're on Windows) ?
  • Did you try getting access with the serial port ?
To be precise, I'm not familiar with Brocade Switches, however the CLI looks quite similar to a Cisco one from what I see here :
https://www.alteeve.com/w/Configuring_Brocade_ICX-Series_Ethernet_Switches
(I almost bought some similar switches, as it seems they support BGP and OSPF 😉 )
Edit : I just checked the zip file and content with an AV (clamAV) just in case something was fishy in the archive on that 1st page, looks clean from my side.
