Does RTX 4070 super fit Phanteks P300 case?
Go to solution Solved by OddOod,
Nevermind.
The P300 supports cards up to 330mm
Aside from these specific makes, you should be fine
Like said in the title, I wonder if a 4070 super with its power adapter would fit a Phanteks P300?
Which exact model?
5950X/3080Ti primary rig  |  1920X/1070Ti Unraid for dockers  |  200TB TrueNAS w/ 1:1 backup
Nevermind.
