Meshify C worse cpu temps than mini itx case
xxx68
Hello, i just moved my system from mini itx Fractal Design Nano S to atx Meshify C and my cpu (9900K) max temps  are about 7 C worse than in nano S. I did expect quite opposite... why is that ? In nano S i had two 140mm fractal fans in front as intake and in Meshify C i have 2x 140mm front intake and 1x top 140mm exhaust all of them be quiet shadow wings.  Cpu cooler is dark rock pro 4.   Meshify C is picture n.1 and Nano S is n.2  Thank you.
looks like the GPU can breathe more so it could be spitting more hot air at the CPU
try a rear mounted exhaust instead of a top, or have your tower cooler blow up instead of back
Primary PC:
I think moving the exhaust to the back would be more beneficial than having it in the top for airflow in your case.
Maybe your new fans are running at lower RPM, but I still don't think that'd affect temperatures that much.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
Meshify C cant fit a 140mm fan in the rear. But the case did come with a X2 GP-12 which could be used instead.
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
Thanks for the answers i will try to add 120mm exhaust fan at back and test it
Potential reasons:
- Different fans, therefore different airflow
- Pressure loss through ventilated top
- Cooler got dodgy mounted during the case transplantation
- GPU contributions to case ambient
This may be a major issue indeed.  If the OP tests it with a 120mm fan in the rear, I'd advise putting the closed top panel on the case instead of the magnetic mesh.
That's also a possibility, especially if you lifted/held the whole thing by the cooler or if you used the opportunity to apply fresh thermal paste.
The top exhaust might be doing more harm than good. Try using it as top intake near the front instead to provide the cooler with more fresh air.
