FPS drops (Is my PSU not enough for my system?)
On 1/28/2018 at 8:09 PM, Eric A. said:Hi!
I've built my first system but since then I have experienced FPS drops/stuttering, this are my specs:
Ryzen 7 1700 @ 3.5GHz
16GB RAM (CMU16GX4M2C3200C16) @ 3000Mhz
GTX 1080ti Aorus (GV-N108TAORUS-11GD)
Motherboard: Aorus Gaming K5 AX370
SSD 480GB
HDD 480GB
PSU 750W 80 Plus Bronze: EVGA SuperNOVA 750 B1
Monitor: Asus Predator XB271HU 2560x1440 @ 165Hz
(by now I only have 2 games Battlefield 1 and PUBG)
The first days stuttering (sometimes crashes) were caused by a high usage of pagefile instead of RAM, after fix the pagefile problem that was causing crashes on games and constant stuttering, I noticed some micro-stuttering every 1~2 minutes, using afterburner I have noticed there are energy drops on GPU (the energy on the power % chart sometimes goes to 50% from a 90 %) but sometimes those energy drops not match with the FPS drops, sometimes it does. another thing I also have noticed is the frametime which sometimes is very high (300 ~ 500 ms) the systme temperature underl full load are great both CPU and GPU has never reached 70° -celsius degrees- (I believe 65° is the highest temp I have seen while gaming).
Things I have tried:
Clean installation of Windows 10
Search for virus
Install all C++ libraries
Run the system without any OC applied
I have to mention that my RAM is running at 3000 MHz because at 3200 MHz my system isn't stable, right now I can't stop my GPU fans once they start spining the only way to stop them is rebooting Windows (both afterburner and aorus graphic engine don't detect the fans speed), and for last I have noticed at the BIOS that the voltage on the CPU vcore are higher when I use the default frequencies than with OC applied (I've reached 3.5 GHz without increasing voltages on the CPU)
I'm attaching some files where you can see my FPS drops, voltage, temps, etc..
I'll be very grateful for any help.
*English isn't my native language, I'm apologize for any grammatical error*
BIOS volatge:
This are the files I've uploaded I don't know why the other links doesn't work
Have you tried running memtest on your memory to make sure its stable? I set some overclocks that weren't stable, and received roughly 60% of the performance you'd expect from Ryzen. Something you could try is setting your memory to Command Rate of 2T. You could also try to loosen the timings. You could also set the DDR4 voltage to 1.4v. One of Ryzen's memory voltages runs at half the DDR4 voltage, and bringing it up to 1.4 increased my stability. I am of strong opinion that this is related to the memory. My last motherboard couldn't get my Flare X memory above 2800 Mhz, and this ASUS Prime X370 Pro struggled to get it to 3200Mhz.
