Is & why is Crossfire better than SLI?
Guest
I have a g-sync monitor
for my next upgrade should i wait for pascal (feels like the gtx 970 is getting weak) or get an r9 390 and maybe crossfire that?
the title question
Crossfire scales better since the SLI bridge hinders performance and CrossFire is done via the PCIe bus.
I would wait for Pascal.
And @don_svetlio said.
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
the title question
wait for pascal
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
Wait for pascal due to the monitor, the sli bridge hurts performance potential, xfire doesn't have that issue
Yep - the SLI bridge was introduced in the 90s by 3DFX - it's outlived it's usefulness
wait for pascal
Pascal is Q3 2016 for gaming and Q1 2016 for Quadros
^^^ this
NVidia is stupid and uses a proprietary connector for SLI.. Making it slow and stuttery. Crossfire-X uses the PCI-E bus which is how ever many times faster than the SLI fingers. That's why it scales way better even with only two GPUs.
About your monitor, I'd wait for Pascal if you want a better GPU. That, or you could buy another 970 now. But be wary, the 3.5GB frame buffer kinda suffers in some games.. :/
I used to be quite active here.
^^^ this
id hardly call it slow and stuttery it might be technically inferior to sli currently but as someone who runs SLI it still performs quite well if the game is set up for it.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
Yes but he has a gsync monitor already (which as you know aren't cheap) so either he waits or gets a 980ti which is the only nvidia gpu I'd still recommend over a AMD model based on performance (though that is 600 bucks which he may not have)
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
still i would wait im using 1 780 and i am waiting although when is the titan coming out is that q3
I missed that - yeah, wait for Pascal. 1080 Ti will leave the 980 Ti in the dirt
Titan is Q1 2017 likely. Like the other titans before it
Yeah, under a year? I would wait before splashing a few hundred.
^^^ this
This is just plain wrong.  SLi bandwidth is not limited by the SLi bridge, and performance is equal to the PCIE implementation that AMD currently has.   Faster connections between the 2 GPUs does NOT increase performance, cos it was never a bottleneck to begin with.  AMD's Crossfire bridge however was much slower than the SLi bridge, and that forced a move to the XDMA standard cos they couldn't fix the dual GPU stuttering any other way.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
i thought it was going to come out early to compete with amds stuff
except pascal will use nvlink, which is better than both SLI bridge and PCIe
When has Nvidia ever been competitive with the Titans? It will likely be 1500$ since HBM2
Isn't Nvilink done via PCie anyway?
Wait so why does it scale better, is it simply more optimized? I also thought it was the bridges fault, or is the performance scale difference a myth.
First and foremost, since you have a Gsync monitor, stick with Nvidia.
Secondly, what others have said is true with crossfire vs SLI scaling (CF scaling is a little better). However; I'm currently running crossfire 290's and am in the process of getting out of this setup. In games that do take proper advantage of CF, the performance is really good (like >980Ti good). But, the number of games that do properly support CF vs the number that don't make it not worth it, IMO, based on my own experience. This is why I'm ditching the CF 290's for a single, more powerful GPU.
So here's what I would suggest; take the money you would be spending on a 390, sell your 970 and get a 980Ti instead. Better, more stable performance in most games and better overall user experience.   ;)
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
I'd wait, In about 2-3 years 4k will be a possibility. And card's then will be the same price and outperforming 970/390 by a long shot. Thats my idea anyway (saving up now for awesome watercooler custom rig).
Anyway If you can't wait get another 970 (since you already have 1)
Might add this later...
http://blogs.nvidia.com/blog/2014/11/14/what-is-nvlink/
doesnt sound like it...
they say its faster and more efficient that PCIe, so it must use some other kind of interconnect
never said the price is competitive :P
I find it sketchy - I hope we don't go back to the era of proprietary GPU boards. That would suck
