Here's my full stats:
7800X3D
Asus X670E-Pro WiFi
EVGA FTW3 3080Ti
64GB GSkill FlareX5s CL32 DDR5 6000Mhz
Samsung Evo 980 Pro
I'm having a few issues where performance feels like it's lacking, I mainly stream with OBS & play Escape From Tarkov (I know it's optimized like shit), but quite a few weeks ago I had no performance issues within the game itself. I've noticed some performance loss in other games like Valorant for example. For the performance loss in Valorant, I've noticed a drop from 1300FPS to 700. I know I don't need that much FPS as it's a waste to render more than what my 240hz can display, but the loss of performance makes me wonder if something else is going on.
I've tried EXPO on/off, custom timings, and disabling scheduled GPU settings in windows. Yet I can't seem to shake the issue. I've made sure I'm not overencoding in OBS, and there is no rendering lag whatsoever. Yet the major issue is that OBS interface, and a VTubing model (3D ran through VSeeFace) will begin to lag, but NOT the game footage at all. I've checked settings in the VTubing app, and I keep it up on my other monitor. It stays at a stable 60FPS with no stuttering or issues when this happens.
I've tried monitoring with HWInfo64, noticed that my GPU sits about 90W when streaming basic things like Blender work, but once I'm in Tarkov, I'm up to 180W-260W peaks. Clocks seem normal, and I don't really see any issues there. I also ran DDU and did a clean custom install w/o any of the extra stuff that Nvidia installs. Same issue. I thought I had solved it by disabling my iGPU on the 7800X3D but it doesn't seem to have solved the issue.
I'm at a complete loss as to what this issue could be, I feel like I'm lacking performance when I just had no issue with performance just a few weeks ago. And one last thing, I know FlareX5S aren't on the compatible list of RAM for this board, but I've read quite a few things about how well FlareX5/x670e/7800x3d runs.
Here's a little video clip of the issue: https://imgur.com/a/Ge8DEn8
so, besides the hilariousness of the video, i dont see anything wrong??
you say performance loss... well... maybe... there's so much stuff running, that would be hardly surprising...
thing is stuff gets updated and whatnot,  tarkov, as you know, is notorious for performance issues...
i think you need to specify the actual issue better in order for anyone to help you tbh.
i also recommend running firestrike benchmark (demo on steam) and *link* the result here..
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Welcome to the forums!
Can you do some heavy stressing to see where your limits are? Looped cinebench and furmark. What temps do your components get to?
Also, LOVE that specific card. Best of the generation.
Is there any problem with gaming when not streaming?
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2
Ryzen 7 5800x - XFX RX6600 - Asus STRIX B550i - 32GB DDR4-3200CL14 - Corsair SF750 - Lian Li O11 Mini - EK 360 AIO - Asus PG348Q
In the video you can see the 3D Model itself, and audio dB bars lagging, *but* no other part of OBS is lagging... for example the game footage is a clean 60fps. I double, triple checked that my 3D Model software is running fine, and it is. No issues there. So I'm starting to think it's some weird OBS issue.
Either way, it only happens when tarkov decides to cap out my GPU. Which isn't 100% of the time, it varies.
Yeah I'll do some stress tests, I ran OCCT in the past (40ish days ago) with no issues at all. I ran it overnight to check RAM issues as I had a bluescreen early on, but haven't had one in >60 days.
Unfortunately not, and I thought it was OBS getting encoding overloaded, or causing an issue there, but it doesn't seem to produce the same issue when recording at an even higher bitrate with the same settings as streaming to the ingest servers.
