DRM printing paper.... How low can they go now?
Beerzerker
Summary
Seems now Dymo, a manufacturer of printers has cooked up a new way to make their printers exclusely use their own brand of printing labels.
Quotes
Quote
"The new label rolls come with a booby-trap," writes Doctorow, "a RFID-equipped microcontroller that authenticates with your label-maker to attest that you bought Dymo's premium-priced labels and not a competitor's. The chip counts down the labels as you print them (so you can't transplant it to a generic label roll)."
"The idea is that by doing this, users are locked into buying Dymo consumables for the life of the product."
My thoughts
Talk about a new way to make sure your customers pay you again and again just to use a product they've already paid for and if they don't.... well, you know.
DRM for printing paper and labels....
What could possibly be next?
Sources
 Dymo causes a stir by adding DRM to printer paper | ZDNet
The Worst Timeline: A Printer Company Is Putting DRM in Paper Now | Electronic Frontier Foundation
"If you ever need anything please don't hesitate to ask someone else first"..... Nirvana
"Whadda ya mean I ain't kind? Just not your kind"..... Megadeth
Speaking of things being "All Inclusive", Hell itself is too.
Wait, who's Dymo?
*Checks internet*
Ah.
Well, someone might be able to hack it. But it's too bad they didn't call it "unhackable", that certainy would've accelerated it.
"A high ideal missed by a little, is far better than low ideal that is achievable, yet far less effective"
If you think I'm wrong, correct me. If I've offended you in some way tell me what it is and how I can correct it. I want to learn, and along the way one can make mistakes; Being wrong helps you learn what's right.
Dymo have been around forever. Early ones were mechanical and deformed plastic tape. If you look it up you'd probably recognise the look, even if you didn't know what made it.
Modern ones have gone the thermal printer route (paper and plastic) and are quite handy. Guess I can't be too surprised they want to lock in their revenue stream on consumables.
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
Just now, Caroline said:
What's next? DRM protected bread that only works with this (amazon.com) stupid toaster?
I'd say it's more likely to be the other way round. A stupid smart toaster that only accepts specific bread.
I can imagine it now. You go to the website of the toaster manufacturer to order your bread, sign into your Toaster Account™, and it generates a unique ID for each slice of bread you order, which is burned into the slice as a datamatrix. Every time you start the toaster, it scans the slices of bread and checks the IDs with the server to make sure that your account is allowed to toast that particular bread slice.
____________________________________________________________________________________________________________________________________
pythonmegapixel
into tech, public transport and architecture // amateur programmer // youtuber // beginner photographer
Thanks for reading all this by the way!
By the way, my desktop is a docked laptop. Get over it, No seriously, I have an exterrnal monitor, keyboard, mouse, headset, ethernet and cooling fans all connected. Using it feels no different to a desktop, it works for several hours if the power goes out, and disconnecting just a few cables gives me something I can take on the go. There's enough power for all games I play and it even copes with basic (and some not-so-basic) video editing. Give it a go - you might just love it.
For myself, DRM should only be used on physical products like this when there is a need for it, or if it's just a warning (so you know it's not genuine).  [Well to an extent]
I'm okay if DRM is used to lock out features (which have a paid option)...but only if it's clear that it's being done so.  An example being if you could buy a CPU with 4 cores but instead of burning off the other 4 cores you have an option to pay for an upgrade to unlock it (with the concept that in general it lowers the cost by only maintaining one SKU).  Other than a few limited cases, DRM I don't think has any purpose.
3735928559 - Beware of the dead beef
Label printer/machine from Brady already have an electrical ship that have a counter of uses. I use one at work. Tho I have no idea if it's something special that don't allow others to make copy chips as I have never tried personally.
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
I purchased the 5XL before realising what they had done with the nfc BS at work. I used the 4XL printer and it worked perfectly for what I intended it for. So when I switched jobs I purchased the 5XL thinking it would be better! I couldn't even use the tags I got through a 3rd party and Dymo doesn't make the kind of tags I need. I returned the piece of shit and sent a bad message through my vendor.
I hate stupid stuff like this. Ruined a perfectly good product. Im actually happy to see them getting bad press!
wow, thats crazy. I use a Rollo label printer with 3rd party labels just fine. Glad I didn't go with Dymo. I guess at the very least, they are very open about it. This is on their amazon product page
This is disgusting.  A completely unnecessary move.  If they aren't selling enough labels then it's because they are charging too much.  You know that free market concept big companies keep telling us is important? I guess it only applies to them being free.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
obligatory "their platform, their rules" comment to please the corporate slaves in this forum
One day I will be able to play Monster Hunter Frontier in French/Italian/English on my PC, it's just a matter of time... 4 5 6 7 8 9 years later: It's finally coming!!!
Phones: iPhone 4S/SE | LG V10 | Lumia 920 | Samsung S24 Ultra
Laptops: Macbook Pro 15" (mid-2012) | Compaq Presario V6000
Other: Steam Deck
<>EVs are bad, they kill the planet and remove freedoms too some/<>
I've got a little handheld Dymo printer from 2009 that I use all the time for labeling the folders and folders worth of owner's manuals I keep in my file cabinet, so fortunately I'm able to use label spools from other brands
Highly knowledgeable in all the obscure 2000s hardware & software you'll never need to ask about
4 hours ago, WereCat said:
company that I have never even heard of
4 hours ago, J-from-Nucleon said:
Wait, who's Dymo
LOL, they practically invented the label maker and have been around near 65 years.
I use a dymo label printer at work and it works really well.  I will for sure not be upgrading to another dymo product with this label lockout. .  There's a lot of other options on the market now so it's near financial suicide for the dymo line.
1 hour ago, poochyena said:
Well the official one is likely better quality.  So there is a slight advantage; is it worth the 4.5x the cost...absolutely not (unless you need it for the consistency and quality...which I bet most won't).  Then again you can do trial and error to find ones that likely are acceptable quality.
An example of something similar was with a thermal printer one of the cheaper rolls didn't have uniform coating on some of the rolls/bad coatings.  As a result it didn't match the quality needed for the print receipts at the business (some of the receipts were fading to quickly as well, a few rolls had half the roll missing the thermal coating).  Tried different varieties but couldn't find any that matched Zebra's thermal paper roll...so eventually had to bite the bullet and just print using those rolls (as it was given to customers).
Not saying it justifies at all, but often time I find 1st party stuff is just "better" (more costly but better).  Front line employees not recognizing that they have to just reprint or switch the roll and wasting time calling IT claiming the printer is acting up.  Sometimes it just adds up in costs to be more than just buying the more expensive stuff in the first place (a very limited scenario though).
I would say that I generally still buy the generic rolls (and just try finding a supplier of the generic stuff that has consistent enough quality)
intel is already trying this with their enterprise CPU's.
except that it's a subscription service and when the CPU is discontinued, the user no longer has access to a feature that's been arbitrarily locked away.
imagine getting a 24 core CPU but only having access to 2 of the cores.
but how would you access them? by paying intel!
it's like that secondhand hand activation thing that happened a few years ago (i can't remember who did it, it was either EA or ubisoft) where in order to play a secondhand game you bought off a friend, you had to re-activate it. i remember this going very poorly and the entire system being dropped.
imagine if intel did the exact same thing for their consumer CPU's, oh how this would back fire.
*Insert Witty Signature here*
System Config: https://au.pcpartpicker.com/list/Tncs9N
Yea, well in cases there are very fine lines in my opinion between what you get and what DRM should control.
Actually another example would be Tesla's and their heated rear seats (available in all vehicles behind a software lock, one time purchase).  For them, splitting the line into different SKU's might be more expensive than keeping a single SKU, but software locking (and hoping that enough people will buy the heated seats to compensate for it being in all vehicles).
So I've searched 30 stores in my country and they all literaly only have Dymo label markers. Since I never had to use one I guess that's it. But nobody sells anything from them except label markers.
28 minutes ago, Heliian said:
What about Zebra?
scanners and eticket printers, just few of them
Can your order online in your country?
lol, what kind of question is that?
