Long ethernet cable vs 3-4 WiFi bars
Ethernet is designed to work up to 100 meters. No matter if the cable is 1 meter long or 100 meters, the performance would be exactly the same (* see fineprint). You'll get super low latency since the signals are traveling at super high speed ( ~ 299,792,458 meters per second) and very high reliability, while through wireless the data has to be arranged in packets, sent through the air and be reflected by walls and shit, arrive at the other end and converted back into ethernet packets or data may have to be re-transmitted in case of errors.
* fineprint : depending on the quality of the network cable you use, some network cards may have problems with very long cable lengths IF energy savings options are enabled in the network card driver... see "green ethernet" or "low power" modes in the network card's driver configuration. By default, most network cards enable these "green" features which are supposed to lower the transmission power of the network cards or adjust the power dynamically in order to save maybe a third or half a watt of electricity.
Some kinds of cheap ethernet cables are made out of copper clad aluminum (CCA, aluminum wires coated with a very thin layer of copper) instead of pure copper because these makes such cables cheaper (copper is more expensive than aluminum). The aluminum in the wires increases the resistance of the wires and this means if you have two cables of same length, you need more power to transmit data through the aluminum based cable in order to get the same signal quality on the other ends.
For 5-15 meters of cable, the composition of the wires doesn't matter, but at 60+ meters, it does matter.
