Pyautogui does not detect images that aren't 1:1
12345678
from the docs it seems that "confidence" does the trick , but it does not
x1, y1=pyautogui.center(pyautogui.locateOnScreen('image.png', confidence=0.8))
print(x1, y1)
by itself then it works fine.
if you put the same under a composite image like
then it does not work anymore
Are you talking about the image you're passing as a parameter to the function, or are you talking about the image you're looking for in your screen?
Also, do you have opencv installed?
FX6300 @ 4.2GHz | Gigabyte GA-78LMT-USB3 R2 | Hyper 212x | 3x 8GB + 1x 4GB @ 1600MHz | Gigabyte 2060 Super | Corsair CX650M | LG 43UK6520PSA
ASUS X550LN | i5 4210u | 12GB
Lenovo N23 Yoga
both? the image is passed as parameter to the function, in which the function should give the xy location of the image
if the image is by itself it works, if the image is in a bigger image with other stuff, it fails
yes it is, otherwise it throws an errror
