@Kwee I called out your sensational bullshit when you were making your original thread and subsequently decided to fill it with paranoid conspiracy theories, but here we are. It was a bug.
Quote
like last drivers (17.2.1) re-enabled async-compute for GCN1 GPUs. Not sure how much will impact games (Currently my 280 is used as slave GPUs for non-game applications), but at least This should cause less problem to developers.
Here's a shot by GPU View, as you can see, the compute queue is back and runs in concurrency with the default queue. Please note that some flip and presentation issues are caused since the GCN1 GPU does not directly output to the monitor (Which is controlled by a R9 380X, to GCN3 GPU) and all is handled by WDDM magic.
NOTE: there is no mention of this fix in AMDs official patch notes. I have checked, twice.
Not much to say here. There was a bug, it's importance and impact was blown out of proportion by fanboys, and it was fixed.
As we get more sources, ill try update the OP.
Source: http://www.bitsandchips.it/52-english-news/8053-welcome-back-asynchronous-compute-queues-gcn-1-0
https://linustechtips.com/topic/738455-gcn-10-async-compute-issue-fixed/
Good to know, people tend to overhype things like that without any further analysis.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
heh Ryzen
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
really?!
AMD said nothing when they removed Async Compute from GCN 1.0 and again said nothing when they put it back
in the mean time you had a lot of people on AMD's forums asking what was going on .. with some AMD rep blaming game devs -_-
analyze that
4 minutes ago, zMeul said:
really?!
analyze that
null-hypothesis. You cannot prove or disprove your proposition, so your entire premise is irrelevant.
1 minute ago, Pohernori said:
heh Ryzen
That too, and many more... I personally just gather all of the "leaks" and "rumours" and when people ask about Ryzen or Vega I'm just telling them what info floats around the web, adding that this isn't confirmed info.
2 minutes ago, zMeul said:
really?!
analyze that
Another sensationalistic comment from you, see the entire point of this post is to inform people that it was a bug and it got fixed. Right under it you say that AMD "removed" Async Compute and put it back again. Come on, not everything has to have a hidden conspiracy theory behind it.
"bug" what the fuck does that mean?
does this software walks around on it's own legs? does it delete itself? truly amazing if it managed to do that
"software bugs" do not exist! it's the hipster way to say the software devs fucked up / didn't do their job properly
conspiracy?! what conspiracy :|
what happened, most likely, was that they discovered issues with GCN 1.0 and removed Async Compute without telling anyone; they fixed it and added it back .. again without telling anyone
It means that either yeah, someone, somewhere screwed up or for instance when they added another feature to the drivers it was conflicting with the Async on GCN 1.0 and it stopped working. Stuff like this happens, you have no idea how VMware (which is the most-commonly used virtualization software in enterprise environments) is fucked up in both GUIs, one feature works in the web vSphere client and the same feature doesn't work in the regular vSphere client, there is another feature that works only in the regular client and isn't shown in the web client at all for some reason. Won't tell you which ones exactly, I can only hint that they're related to configuring storage under the iSCSI protocol.
Stuff like that happens. Those people are still only people and do make mistakes.
insert conspiracy ecks dee
Hmm, I really am confused on how they accidentally crippled asynchronous compute performance. Oh well, they fixed it.
that's what incompetence looks like, from the senior programmer to the individual programmers
changes made to the code needs to be cataloged and revised and not added with the shovel
You can actually pretty easily prove whether or not AMD has said something about its removal and subsequent reintroduction as well as the statement that AMD reps blamed game developers. At least try to apply the scientific method properly.
My Build:
CPU: i7 4770k GPU: GTX 780 Direct CUII Motherboard: Asus Maximus VI Hero SSD: 840 EVO 250GB HDD: 2xSeagate 2 TB PSU: EVGA Supernova G2 650W
3 minutes ago, XenosTech said:
Think I remember that thread... God damn that xeon comment from a while that that he got flamed for while for xD
Everyone knows that the reason AMD disabled Async Compute for GCN 1.0, is beacuse its not GCN 1.0, but actually a Maxwell GPU. Duh
Sigh you do know nothing made by humans is perfect.. not even the bloody tech we use is perfect but it works
Dang I should of gotten me one of those maxwell titans eh ?
Main PC:
CPU: Ryzen 5 3600  | GPU: RTX 2060 | PSU:  | Memory: Corsair Vengeance RGB 3200Mhz 16GB | OS Drive: Western Digital Black NVMe 250GB | Game Drive(s): Samsung 970 Evo 500GB | Motherboard:  | Case: Fractal Design Define R6 | Monitor(s):  | Keyboard:  | Mouse: Steelseries Sensei 310
NASUS (NAS)
CPU: Intel Xeon X3440 | Motherboard: Super Micro X8SIL | Memory: 16GB DDR3 1066Mhz ECC UDIMM | HBA: Dell Perc H200 (Flashed to IT Mode) | Drives: 3x 16TB Seagate Exos x16, 2x 6TB Seagate Enterprise, 1x 6TB WD RED
RENEKTON (NAS)
CPU: Intel Core i5 4570TE | Case: Fractal Design Define S | Memory: 16G DDR3 1333Mhz SODIMM | HBA: LSI 1068E (Flashed to IT Mode) | Storage: 4x 3TB Hitachi, 2x 3TB WD RED
Can you prove or disprove if AMD is right in their allegations?
No. Because none of us has the information or insight on the topic from AMDs perspective.
Can you thus claim AMDs claim is false?
No. Because you cannot prove or disprove your hypothesis simply by the fact that we will most likely never get the truth to the story about AMD blaming devs.
There is no logic in blaming AMD without knowing the counter argument/proof to their claim.
If you are to criticize my critic, atleast make sure your argument stand up to rigor.
did anyone asked to be perfect?
when you have a issue that interests both developers and consumers, you inform people about it - why do they even have release notes with each driver pack then?!
I propose that each driver update is like a RPG mini-game, you have to discover on your own what's new, what's fixed and what's missing :dry:
You know somethings don't show up in a test environment especially when that problem isn't even related to what you're testing for... If they're testing for stability and comparability an a-sync test probably wasn't even in order since it didn't really affect neither of those things.
Main PC:
NASUS (NAS)
RENEKTON (NAS)
Because you weren't informed does not mean they did not respond. Get your facts right and put some sources behind your claims.
They even talked about it at pcper: (@1:00:07)
they're testing for shit
software doesn't modify itself - you just don't add some game compatibility and boom, all Async Compute for GCN1.0 goes missing - that's not how software works
I'll show myself the door before I say something that gets me banned. @Prysin you care to explain to this one ?
Main PC:
NASUS (NAS)
RENEKTON (NAS)
you're quoting ame and passing the ball to him?! have some balls
do you even have the slightest idea of how software development works?
you say that on what basis? your extremely extended but undocumented and unproven knowledge about software and software development?
He cannot see my posts, he has blocked me a long time ago
Seems he likes to block ppl who prove him wrong ? I mean it's a simple concept that we've seen time and time again... Dev make a change to their code and something else breaks, totally normal. Some times you pick it up in testing some times you don't, just a matter of how what you're testing for at that specific time. Async being disabled didn't render the cards unstable, dead nor caused BSODs
Main PC:
NASUS (NAS)
RENEKTON (NAS)
5 minutes ago, M.Yurizaki said:
Wow this thread derailed fast.
Really? you think so?
Well, all in all, this news post is a "statement". There isnt much to discuss here, other then @zMeuls conspiracy theory.
Over half the posts are you guys bickering about it so...
