source: https://www.computerbase.de/2016-09/grafikkarten-speicher-vram-test/
this is not the 1st time I discuss about this and sure it won't be the last
about 3 weeks ago, Digital Foundry made a analysis of surrounding GTX1060 the 3GB variant and 1080p gaming - the specific case was Rise of the Tomb Raider
what they found is that even at 1080p, 3GB of VRAM can be insufficient given the right (wrong) circumstances, more here:
today, ComputerBase.de took the matter a bit further and made a FCAT frametime analysis of couple of games at 1080p
hardware used: GTX1060 6GB and 3GB models, RX480 8GB and 4GB models and in one case RX470 8Gb and 4GB models
the games tested:
  • CoD: Black Ops III - high and extra quality settings
  • DeusEx Mankind Divided - high, very high and ultra settings
  • Mirror's Edge Catalyst - ultra and hyper settings
  • Rise of the Tomb Raider - high and very high settings
let's dive in! 1st up CoD BO3:
at high setting, between RX480 models (4 and 8 GB) there isn't much of a difference; when switching to GTX1060, there is some notable frametime bumps here and there, nothing spectacular
however, when we jump to extra quality settings things get interesting:
both GTX1060 3GB model and RX480 4GB model see significant increase in frametimes across the run
2nd contender, Mirror's Edge
at ultra settings, RX480 4GB model seems unaffected, while GTX1060 3GB model goes off the rails:
switching to hyper settings, RX480 behavior remains unhinged; GTX1060 3GB variant goes mental with frametimes hitting almost 100ms:
3rd up, RotTR
right off the bat, at high settings GTX1060 3GB model is out of it's element:
switching to very high settings, it's clear that the 4GB RX480 can't handle it very well; 6GB looks to be the minimum for this quality setting:
last one, DeusEX - for this one, ComputerBase.de "ditched" the RX480 cards (had to be returned back to Sapphire) and replaced them with RX470 variants
at high settings, 3GB GTX1060 cracks, the 4GB RX470 has some itches here and there but nothing spectacular:
at very high settings the trend continues, this time the 4GB RX470 get noticeably affected by the lack of VRAM:
and lastly, ultra settings ... the 6GB GTX1060 looks like it's choking:
the conclusion: in these times, it looks like even at 1080p games demand more and more VRAM - gone are the days where 2 GB were enough, we see even 6GB equipped video cards hitting the ceiling
ComputerBase.de's conclusion: VRAM 6GB should it be in the mid range; don't cheap out when buying graphics card, avoid 2GB models at all costs
Quote
VRAM 6GB should it be in the middle class
Conclusion: From the middle class 3D accelerator should have at least 6,144 MB of memory already. And Deus Ex: Mankind Divided shows that can be sized rather too short, only the Radeon RX 480 comes with 8 GB without penalty thereof. However, the discussion about whether this is justified is not included in this report.
Even with cheaper graphics cards should not be saved on the memory. Models with 2,048 MB, as they, for example, of the new Radeon RX 460 are should absolutely avoided and instead the double memory to buy.
https://linustechtips.com/topic/660685-1080p-the-vram-problem/
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8542824
Its because more and more is being rendered now. Last time games kept levels small and focused to reduce RAM and VRAM usage. Games also had less detail. More details means more memory. Imagine if every texture in the map is taken using a DSLR and takes a few MB each. Reusing each texture does require more buffers but not much more ram but for a whole game level that translates to GBs for all the graphics. objects further back may also be rendered at full quality but at least now you can walk right up to a wall or object and read all those small words and fine details and print with the object seeing clear rather than blurry like it doesnt have enough pixels.
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8542844
waow this is late, in end of June I did a status update showing that you can max 4gb of vram out at 1080p. Everyone called me crazy, but who is laughing now.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8542861
Just now, The Benjamins said:
FYI 470 is a 4GB only card Officially, but because its based on the 480 it can be made as a 8GB model.
Did AMD not launch a 8GB model or am I blind
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8542911
@zMeul This is not news, this is only news for people who are living under a rock or don't want to see reality.
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8542912
You not remember the post maybe a month or so ago about the 3GB 1060 where zMuel was getting pushed into a corner over whether or not 3GB is enough?
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8542942
470 is a NON ref only but it is basically a 480 so AIB can easily make a 8GB model if they chose to but it is not a official thing. I own a 470 4GB that is 480 ref design and it works with the 480 EK block that I got.
its like the 290X 8GB its a unofficial version.
if you want to annoy me, then join my teamspeak server ts.benja.cc
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8542955
Of course is not. Also does slightly lowering the setting still solves this non-issue? Of course it does.
Meanwhile I've found some footage of you:
Image result for beating a dead horse
Current Rig
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8542956
sure, but I did a status update 3 months ago about 1080p being able to max out a 4gb card and after that I have been in threads showing it and I have been called crazy, but I don't care what they think, because those people live in 2012, not 2016.
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8542974
Wow .
And here i was expecting my 4gb 290x CF setup would last a long time ...
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8542982
Don't see the reasoning behind the negativity in this thread. I see a well explained point with tests and data to support that point, and members that have been very active in the same forum acting like they don't also agree with said point, or too blinded to the helpfulness of the post by the 'I did it first' rationale. C'mon guys...
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8542984
  Reveal hidden contents
do you want a card that is limited by vram? Because I don't.
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8542993
The 1GB on my GTX 560 was still enough to play Witcher 3 and many other games that came out recently (not sure about dx12 titles, never tried those out).
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8543003
Depends on how much money it saves me.
On the 480? No thanks.
On the 470 and the 1060? Legitimate savings to be had for 1 or 2 settings so slightly worst most gamers wouldn't even notice if not pointed out.
Current Rig
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8543007
Using the vram is not necessarily a sign of it being a bottleneck. Efficiently programmed games will use spare vram for caching to reduce loading times. I think 4gb are probably still just fine except in fringe scenarios.
sudo chmod -R 000 /*
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8543014
Blops3 is a prime example.
I'm ALWAYS at maximum Vram capacity using even medium settings, but I use High obviously with a GTX970, (game actively caches MUCH data), and my pagefile gains 10GB of data when the game is running.
Smooth as silk though.. does not induce issue.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8543041
This is why i got an rx 480 4GB as soon as i could so i had one with 8GB shipped.
And that's why i overpaid a few weeks later for rx 480 8GB models for other systems :D
Futureproofing ftw! :P
I stick with the idea that mostly nvidia sell cards with little amount of VRAM as part of planned obsolescence.
But that's just my opinion on it :P
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8543051
caching isn't there to reduce load time, to the contrary it increases them
caching is used to prevent texture pop-in as you progress trough the level as new textures must be loaded from the disk drive
when developers want fast loading, they use texture streaming - this also uses less VRAM as textures are swapped in and out as necessary
effect? doesn't look pretty and texture pop-in are quite common
mostly used in open world games
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8543080
blops 3 is a bad port...
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8543154
To be fair to the opposite side of the argument I support (Let it not be said I am unfair) expecting bad ports sadly, should be a given. In fact it should be the rule and not the exception given how common crap ports and poor versions are.
So in a perfect world we shouldn't select cards based on programers being lazy and incompetent.In reality however, yeah it's a given most gamers will inevitably run into a bad PC port, probably more than once per year even.
Current Rig
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8543169
yes, they launched both a 4GB and 8GB model. Officially.
https://linustechtips.com/topic/660685-1080p-the-vram-problem/#findComment-8543173
