What about Water Cooling M.2s?
Solved by OddsCrazyStuff,
As far as I can tell, so is the only time you will get heat issues on an m.2 or a pci ssd, is when you transfer a lot of data to it or from it (I think 100GB+ is required).
So unless you need to do that often, so will normal case cooling do the trick.
Its possible you might get the same heat issue, if you run it for long period of times as well, like with a video editing session, but no data on that is available.
