Please help my first build
Go to solution Solved by Robchil,
15 hours ago, frostymelts said:
i couldnt get the system to start booting, all black screen
the orange light switched to vga, made a click sound and restart, is this gpu problem?
you have a K cpu.. you can take out the GPU and plug your monitor into the mainboard ..
cpu: Intel® Core™ i5-14600K New Gaming Desktop Processor 14 cores (6 P-cores + 8 E-cores) with Integrated Graphics - Unlocked
cooler: Noctua NH-D15, Premium CPU Cooler with 2x NF-A15 PWM 140mm Fans
motherboard: GIGABYTE Z790 AORUS PRO X (LGA 1700/ Intel/ Z790 X/ATX/ DDR5/ 5* M.2/ PCIe 5.0/ USB 3.2 Type-C/Wi-Fi 7/ 5GbE LAN/Q-Flash Plus/EZ-Latch Plus/Motherboar
memory: G.SKILL Trident Z5 RGB Series (Intel XMP) 32GB (2 x 16GB) 288-Pin SDRAM DDR5 7200 CL34-45-45-115 1.40V Dual Channel Desktop Memory F5-7200J3445G16GX2-
storage: SAMSUNG 980 PRO SSD 2TB PCIe NVMe Gen 4 Gaming M.2 Internal Solid State Hard Drive Memory Card, Maximum Speed, Thermal Control, MZ-V8P2T0B
gpu: MSI Gaming RTX 4070 Super 12G Gaming X Slim Graphics Card (NVIDIA RTX 4070 Super, 192-Bit, Boost Clock: 2655 MHz, 12GB GDRR6X 21 Gbps, HDMI/DP, Ada Lo
psu: SilverStone Technology DA850R Gold, ATX 3.0 and PCIe 5.0 Fully Modular ATX Power Supply 850W 80 Plus Gold, SST-DA850R-GMA-WWW
I have check on cables, all cables are in place, memory card slot in with clicks, gpu with clicks, im now worried.
when i do pre-test build. the motherboard flash orange light on cpu then switch to dram for 10 second then switched to vga, immediately auto restart. what am I doing wrong here?
https://linustechtips.com/topic/1569093-please-help-my-first-build/
does it keep restarting?
current PC:
PC configs I used before:
after I remove m.2, same lights flashed from cpu to dram to vga to no orange light, and all my fans stopped working, the rgb lights are still up as usual. this did not trigger endless restart.
after I put storage in bottom m.2 slots, the problem came back again. restart endlessly.
motherboard, gpu, ram rgb is on while problem persist
if you have a monitor connected you should get into bios...
sounds like a DOA nvme.. do you have another drive.. m.2 or sata? you could install windows on to test?
i tried sata samsung 850 evo ssd with windows installed. the problem still persist
I different m.2 slots, all gave the same results.
motherboard orange light on cpu, switched to dram, switched to vga and went out restarting
i removed the cooler to check my cpu, no damaged pins, its all good.
edit* I manage to install windows on the new ssd (confirmed not DOA)
7200mhz ram speed, it can take a good mainboard to get that speed, you might have to set the speed down to get it stabile.
