Cablemod. If you are trying to do this for a regular PSU, just save your money.
https://linustechtips.com/topic/1569090-white-braided-cables/#findComment-16398869
Just now, JakubR88 said:
just was thinking that my case is an MATX case 26Liters so idk if the cable extensions would make cable management a pain
If you want clean look, get a modular PSU and cables you want. Non modular PSUs are not worth the effort to attempt to make them look nice. Extension cables are even worse.
https://linustechtips.com/topic/1569090-white-braided-cables/#findComment-16398873
I only buy modular PSUs but im just trying to find the white cables for it because all i can find on the internet are extension cables 😞
https://linustechtips.com/topic/1569090-white-braided-cables/#findComment-16398875
I literally told you where you can find cables. Cablemod.
https://linustechtips.com/topic/1569090-white-braided-cables/#findComment-16398877
1 hour ago, JakubR88 said:
Im trying to find some white braided cables however i can only find extension cables? is there no way of just getting cables that fit straight into the psu and then into the motherboard and gpu without having to connect two cables together. (uk)
What's the brand and model of the PSU?
https://linustechtips.com/topic/1569090-white-braided-cables/#findComment-16398934
