I am having issues with my GC-WBAX1200 aka AMD WIFI 6E RZ608 aka MediaTek MT7921 with bluethooth has wifi works fine . The only it detects and works with is my phone
it cant see , My bluethooth keyboard and the mouse , my xbox controllers , my stadia controlller and switch pro controller .
What i tried :
Fedora Doc for bluethooth issues
-Arch Wiki
Googling for hours looking for answers
Other Distros ( Arco Linux , Garuda ) in Live environment and installs ( tried nobara for a while and mint )
VM with windows to pair there and pray it works
Nobara Discord
Reinstall of Open Suse tumbleweed
Turning off ERTM
[General] ClassicBondedOnly=false in config
Controllers work fine with cable and have drivers for the xbox ones that support bluetooth installed . it works fine in windows , logistically it doesn't work for me if have to use a cable
https://linustechtips.com/topic/1569096-issue-with-bluetooth-in-linux/
Sounds like you have the same issue I had on my laptop. By default my BT was as "non-discoverable" and there was no option in the settings anywhere to make it discoverable and at the same time Live USB boot worked fine. So while I could find the devices I wanted to connect to my laptop, they couldn't because they couldn't se my laptop.
I had to install "blueman" where I can enable discoverability and connect devices.
