CPU for Radeon RX 7900XT
Solved by Agall,
6 minutes ago, WuWkie said:Hi, I'm planning to upgrade my current GPU to a RX 7900XT and I was wondering if I should upgrade my CPU before or if it'll work fine, I'm currently using a Ryzen 7 3800X
Either buy a 5800x3D if you have a good motherboard+RAM combo already for your 3800x or jump onto AM5.
For AM5, I would either wait a week for the 7800x3D to come out at $450 or just buy a R5 7600(x) at half the price and wait for the 8800x3D. Resale on the R5 7600(x) should be good for a long time since its also a capable basic workstation CPU due to having an iGPU this time around.
Even at 4K, a 3800x would bottleneck a 7900 XTX in most games people actually play by a surprising amount.
