Intel introduces first new ATX Spec in nearly 20 years (ATX 3.0) with ATX12VO and 12+4-pin 12VHPWR connections- Just in time for RTX 3090ti next week
Deadpool2onBlu-Ray
Go to solution Solved by Guest,
32 minutes ago, Ryan829 said:
Summary
 It has been in the works for quite awhile, but Intel is finally introducing a new ATX PSU spec. It sounds like ALL new <450w power supplies are going to have to abide by this spec or face higher component prices.
You mean > 450W and not < 450W, right?  We'll get back to this part when you can clear up what you're trying to say here.
"A new 12VHPWR connector will power most, if not all, future PCIe 5.0 desktop Add-in cards (e.g., graphics cards). This new connector provides up to 600 watts directly to any PCIe 5.0 Add-in/graphics card. It also includes sideband signals that will allow the power supply to communicate the power limit it can provide to any PCIe 5.0 graphic card"
They're not signals.  At least not the wires that the desktop cards will use.  They're just sense grounds.  Read Aris's write up on it.  It has the table on there.
350> watts
Please figure out how to use the > and < signs.  😉
As much as I look forward to getting rid of ugly 24pin ATX Cables/ 2/3x 8 pin PCIE cables, I can see this being a big issue. I can see a situation where 80% of Zen 4 (X670?) and Raptor Lake (Z790?) motherboards use the old spec with the 24 pin power connector, and the other 20% adopt the new standard. This is going to cause a really awkward transition phase where it is hard to recommend the route for builders to take.
Why?  When you're building, you take into account the chassis (ATX?  SFX?), the motherboard (ATX12V?  ATX12VO?) and the GPU (6-pin?  Two 6-pin?  6 & 8-pin?  Three 8-pin?  12+4-pin)  So this is no different.
What it WILL mean in many situations is you won't be able to shove your 10 year old PSU into your 4090 build.  But hey.....  You just spend $3K on a GPU!  What's another couple hundo?
I can see there being a shortage of these new power supplies for sure.
For sure?  How do you come to this conclusion?
Summary
The 4090? is going to pull at a minimum >350 watts, so A LOT of people are going to be looking at new PSU's anyways, why not get the new spec?
Actually, 600W.  Where did you get 350W from?  LOL!  And yes..... Why not get the new spec?
There is also a rumor that some of the AIB 3090tis are going to use the new 12+4 pin connector, while some will use 3x8 pin. What a mess.
That would be a mess.  But remember:  The 12+4-pin is part of the PCIe 5.0 spec.  PCI-SIG has the "old" 6 and 8-pin connectors anywhere in the 5.0 spec.  So if they put something other than a 12+4 pin on the card, they're breaking spec and my guess is PCI-SIG won't let them say the card is PCIe 5.0.
On 3/24/2022 at 8:57 AM, Helpful Tech Wiard said:
Actually, having high efficency at low loads is something a lot of people need.
id rather not be paying hundreds a year from having my psu pull 300w when in sleep….
I don't see that as an issue sleep standard I believe are for less than 1w.  When my computer is sleeping the UPS says 0w.
AMD 7950x / Asus Strix B650E / 64GB @ 6000c30 / 2TB Samsung 980 Pro Heatsink 4.0x4 / 7.68TB Samsung PM9A3 / 3.84TB Samsung PM983 / 44TB Synology 1522+ / MSI Gaming Trio 4090 / EVGA G6 1000w /Thermaltake View71 / LG C1 48in OLED
Custom water loop EK Vector AM4, D5 pump, Coolstream 420 radiator
On 3/23/2022 at 7:50 PM, Caroline said:
Heh, why buy a space heater when you can buy a 600W graphics card.
I spent a lot of time on my 3080 with a custom curve and lowering the wattage (something like 220W with full performance) in the summer its almost unbearable under the desk.  Can't imagine how 600W will feel.  Although that was when I was mining 24/7.
Both the EVGA Kingpin Extreme and the Galax 3090 Ti HOF use 2x600w Gen5 connectors (shared design with 4080/4090 ?) TGP for both cards I think is 516W, and without OC, without shunt-mod they should top out as ~530W like the EVGA FTW3 Air cooler and MSI Suprim.
https://videocardz.com/newz/galax-launches-geforce-rtx-3090-ti-hof-with-dual-16-pin-power-connectors-and-up-to-516w-of-power
https://videocardz.com/newz/evga-geforce-rtx-3090-ti-kingpin-hybrid-revealed-dual-16-pin-power-connectors-and-an-oled-screen
5 minutes ago, Dogzilla07 said:
Both the EVGA Kingpin Extreme and the Galax 3090 Ti HOF use 2x600w Gen5 connectors (shared design with 4080/4090 ?) TGP for both cards I think is 516W, and without OC, shunt-mod they should top out as ~530W like the EVGA FTW3 Air cooler and MSI Suprim.
Holy..... So you will need 6x8 pin PCIE to 2x16pin to power these monstrosities
CPU-AMD Ryzen 7 7800X3D GPU- RTX 4070 SUPER FE MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE-2x1TB Seagate Firecuda 530 PCIE4 NVME PSU-Corsair RM1000x Shift COOLING-EK-AIO 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-ASUS ROG Strix XG27AQ 1440p 170hz+Gigabyte G24F 1080p 180hz PERIPHERALS-Lamzu Maya+ 4k Dongle+LGG Saturn Pro Mousepad+Nk65 Watermelon (Tangerine Switches)+Autonomous ErgoChair+ AUDIO-RODE NTH-100+Schiit Magni Heresy+Motu M2 Interface
These 2 (LAB OC and Kingpin) are dedicated OC (the previous 3080 Ti LAB OC was the only 1000W unlocked card from the factory). So without OC/shunt-mod I doubt both cables are needed (though probably at-most 1 additional 8-pin on the dongle, as OC wise it should go higher than 530W (as it looks like the 3x8-pin dongle doesn't allow 600w on one cable out of the box).
Though I doubt even overclockers will bother with 2 dongles and 6 damn 8 pin cables. A Gen5 unreleased PSU is gonna be very welcome xD. There's rumors of a possible RTX 4000 series 4x cable 8-pin dongle as well.
I have a feeling that the gen 5 power supplies are late. There are the MSI and Gigabyte ones that are "released" but not available anywhere. And they don't have the new atx12vo standard, only the 16pin pcie5 cable. EVGA JUST released their new p3 line of power supplies in October that are atx 2.0 and don't have the 16 pin pcie5 connector. I have a feeling it is going to be dongle time for a while. Also something I noticed that is kind of scummy. The new 1200p3 has been 219$ since release, but now EVGA raised it to $250 because they assume 3090ti owners will need a new high power psu. $250 on amazon as well. Shame on you EVGA for capitalizing on the market.
FSP, Asus and Cooler Master Gen5 are also "released". As for the atx12vo there's only the 2 pre-built from MSI that I mentioned above in this thread. It does make practical sense. atx12vo is not a physical limitation due to physics, it's a "green goal". and Gen5 is byproduct of extraordinary needs, which are in turn byproduct of stagnated moore's law, which is a byproduct of physics limitations in R&D.
4 minutes ago, Dogzilla07 said:
FSP, Asus and Cooler Master Gen5 are also also "released"
Meh. I want an EVGA/Corsair/Superflower/Seasonic one. I currently have a 750p2 and I am cutting it really close with my 3070ti/12600k. I am afraid if I slot in a 13900k, I will have stability issues even if I do not upgrade my gpu. I want a 1200w one but I refuse to buy one without the new PCIE gen 5 connector. Even if new motherboards (zen 4/raptor lake/meteor lake, etc.),  have atx12vo instead of 24 pin atx cables, that is just a simple adapter. I refuse to have 3 or more 8 pin cables chilling(or should i say restricting airflow) in the back of my system if I can avoid it.
do hope higher rated W cards, is able to deal with the heat load. already some are struggling with the current rating and if they can create more surface area between chip to cooler? *becomes dual chip design that is very chippy*
Just now, Quackers101 said:
do hope higher rated W cards, is able to deal with the heat load. already some struggles for some of them and if they can create more surface area between chip to cooler?
Apparently the high end 4000 series cards Nvidia had to gimp a bit because they couldn't keep 500/600w of heat under control without watercooling them. They won't make a Founders Watercooled card because Founders are MSRP and they want that to be an attractive price. AIO cards are usually like 100 bucks more
@Quackers101It's gonna depend on the case and fan setup, computerbase testing was toasty in the case, while HardwareUnboxed was fine in Corsair 5000D. As for dual chips, yeah I also can't wait to see how the 8,9 heatpipe vapor chambers +2kg heatsinks are gonna be able to handle the new MCM designs.
@Ryan829The cooler for MSI 3090 Ti Suprim together with 2x Noctua A12x25 can handle 550-600w NP as is evident by the 3090 Ti reviews/testing handling 530W with no issues like a champ. Just that it becomes 5.3 slot at that point, and most cases and airflow setups won't be able to handle it.
That's why Custom Liquid Cooling is easier, no need to optimize airflow patters, nor mod the case in an ugly way. Just chug in a couple of rads, some great static pressure fans, and voila, done. No hot air pockets, no vortex problems.
Asus/Noctua said new Noctua-cooled GPU cards are incoming, so lets see what they bring us xD
I don't think EVGA knows enough about PSUs to be malicious with regards to their market 😉
It just seems like convenient timing for the "instant rebate" to expire that's all.
Doubt you're using more than about 500W, really.  My desktop fits in 850W with a shunted 3090 mining and a 12900K running OCCT, which isn't even a "realistic" load either.
Workstation:  14700nonK || Asus Z790 ProArt Creator || MSI Gaming Trio 4090 Shunt || Crucial Pro Overclocking 32GB @ 5600 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ Stock || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 3060 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
Sigh...it's turning into a dick measurement of how many power pins you have, much like how many 9999 phases of power delivery you have when your TDP is 300W but the VRM section is 4000W.  Meanwhile I'm drawing 650W on 2x8pin and it's fine...doesn't even get the cables or connectors hot under FLIR.  Ironically this new connector shit is just going to lead to everyone using adapter cables which increase the resistance in the path (because the connectors are always the weakpoint, not the wires themselves).
I don't like having adapter either. That is why I am using this cable for my 3070ti FE. https://www.evga.com/products/product.aspx?pn=100-NK-3000-B9
On 3/24/2022 at 9:48 AM, jonnyGURU said:
That's still not a need.  That's a nice to have.
Jonny,
What about the PSUs that already have the 12 pin cable (that connects to 2x8 pin from the PSU), e.g. Seasonic PSUs with their Micro-fit 3.0 cable?
1 hour ago, Falkentyne said:
Jonny,
You can use that for 3090 Ti.  But since it lacks the two sense pins, it will throttle a 40 series card to 150W.
Which is totally pointless, if the psu cant deliver it just shuts down....
Well, not necessarily.
What happens normally if your PSU is incapable of providing enough power to a system is it will trip over current protection or over power protection and the power supply will shut off, resulting in the system turning off. The system (including the graphics card) doesn't know how much power the PSU can deliver so it will just draw as much power as it needs until the system turns off.
What the new 12VHPWR connector does is by using those additional pins on the cable tells the graphics card how much power the graphics card can draw from the power supply over the cable, the graphics card then locks itself to a lower power mode forcing it to not exceed that power draw. If the graphics card limits itself in how much power it can draw the GPU will run much slower as it can't hit the higher P-states and high clock speeds but it shouldn't shut down unexpectedly.
I imagine the 3090Ti's and possibly future 40 series cards will come with a 12VHPWR adapter since there's not any PSUs on the market that include them yet, so you'd be better off just using the adapter with standard 8pin PCIe cables instead of trying to use the Nvidia 12pin cable. I believe the adapter cables with 3x PCIe 8pin to 12VHPWER will be limited to 450W.
150W per cable. Should be 225W for the card including the PCIe slot, right? And I'm assuming if the card has two 12VHPWR connectors like some of the 3090Ti cards have the graphics card total board power limit could be as high as 375W without any of the sense wires present if both cables are plugged in.
Yes, it is. PSU trips on overload -> change psu. GPU slower than it should be -> normies will get confused where is the issue. Its pointless to try and build protection against human stupidity and definitely no need for a new standard to implement it.
As for power savings AFAIK there is not much of a difference between regular ATX and 12V0, the only difference is in case of 12V0 they moved some PSU parts onto the mobo so they can cheat and claim better efficiency on the PSU.
Edited by jagdtigger
On 3/23/2022 at 8:35 PM, Quackers101 said:
as in 10 > x (is less than x) or 10 < x (is more than x).
Didn't see anyone else touch this so I will.
10 > X  :: 10 is greater than X.
10 < X :: 10 is less than X.
FTFY
BabyBlu (Primary):
  • CPU: Intel Core i9 9900K @ up to 5.3GHz, 5.0GHz all-core, delidded
  • Motherboard: Asus Maximus XI Hero
  • RAM: G.Skill Trident Z RGB 4x8GB DDR4-3200 @ 4000MHz 16-18-18-34
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2070MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 10 Pro
Roxanne (Wife Build):
  • CPU: Intel Core i7 4790K @ up to 5.0GHz, 4.8Ghz all-core, relidded w/ LM
  • Motherboard: Asus Z97A
  • RAM: G.Skill Sniper 4x8GB DDR3-2400 @ 10-12-12-24
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Corsair Vengeance C70, w/ Custom Side-Panel Window
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair AX760
  • Display: Samsung C27JG56 27" 2560x1440 144Hz Freesync
  • Cooling: Corsair H115i RGB
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
The PCI5 Power Supplies seem really late to me. Seems like a giant missed opportunity by the manufacturers to get new 3090ti owners to buy a new psu too
Thank you for the information.  Glad to see the Seasonic micro-fit cable will still work on a 3090 Ti.
Seasonic replied in email saying they are developing ATX 3.0 spec PSU's and they will be announced at a later time.
I guess shunt mods will be a thing of the past on a 4090 card, huh 😞
😳😳 That is not good at all. "developing, announced later time" sounds like they won't even come out this year in time for Zen 4 and Raptor Lake.
