Do you really need 144 fps for a 144 Hz monitor
3 minutes ago, Tan3l6 said:Yup, I'm not disagreeing, I just gave a simpler explanation.
19 minutes ago, Tan3l6 said:Tearing is not Hz nor FPS dependent.
It's just a "misplaced" frame(s). Freesync and Gsync are great for avoiding the effect.
And yeah 144+Hz is good. More noticable at higher framerate but lower also.
You gave no explanation at all lol. You just explained how screen tearing works in a way that only someone who already knows how it works would understand. Saying screen tearing happens due to "misplaced" frames to someone who has no idea what you are talking about (like OP) will be no closer to understanding what causes screen tearing without a lot of additional context, which you have not provided. On top of that, your semantics are misleading. It's true that neither Hz nor FPS are solely responsible for screen tearing, but it is both of them in conjunction that causes it. Any time your Hz is not perfectly divisible by your FPS (which is basically all the time on a 144Hz display unless you lock it), screen tearing will occur.
@Stefanos Lamparas To answer your original question, no, you do not need to be getting 144FPS in every game to fully utilize a 144Hz display. Any amount higher than 60 will make the game smoother, even 70fps. However, unless your display also has Gsync (Nvidia GPU) or Freesync (AMD GPU), you will experience screen tearing (which was explained in the other replies), the degree of which will vary based on your framerate and the game you are playing. Most people find this annoying so if you have the budget for it I highly recommend a Gsync/Freesync display. You won't have to worry about trying to lock your FPS or trying to adjust in-game settings so that you are always at 144 or 72. You can just play any game on any settings you want with no fuss, very nice feature to have.
