Help with my h510
Jevari
So I install my fans like this always on the back of my radiator, someone told me I’ve been doing it wrong and it must be on the front, are they right
The radiators and fans are supposed to be on the inside of the bracket not the outside.
You need the space on the outside for the air to get in.
Right now your radiator is basically against a flat piece of metal with no holes.
agree with the Enderman.
h510 has poor airflow already the aio makes it even worse. but yes mount the fans on the otherside of the bracket.
i do not know why popel still buy anything NZXT h5xx seires products. yes they look decent but have very bad airflow.
what are you cooling with that aio. in that pc case, a good aircooler would have been better performer
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
The airflow is "MEH". With the right fans and the right airflow setup it'll work.
It's not like Bitfenix Enzo bad. But stock, it's pretty bad.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
When is NZXT going to release mesh cases? like h510 elite mesh or sum? that would be good.
Main PC:
Test Rig.
Just Sold
Ask me anything :)
that would be great. I have the H500 now and it barely manages to cool my 8700K @ 5.1 and my Vega 64 Nitro+. And that's with two pretty fast AIO fans, a static pressure optimized RGB fan at the back and a high end, $40 Fractal 140mm at the top. Spent so much because I really love the look of this case and I can reuse those fans through the years.
Mesh H510 would be amazing.
Full Specs
Helios EVO (Main):
Delta - Laptop
The airflow is fine as long as you use decent fans.
The point is to not have mesh, because that changes the minimalist aesthetic and also allows noise out of the PC.
Having the vents on the bottom or back panel makes the case much quieter than any mesh case.
Probably never, at this rate. NZXT has focused primarily on aesthetic cases since the release of the very popular H440, one of the last cases that they had any sort of mesh fronted panel was the Phantom 820.
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
