Help me get my PC to turn on please
I built a PC using the msi mpg B550 gaming plus motherboard. The box says the bios has been updated for ryzen 5000 series CPU’s. But I installed a ryzen 3700X. PC will not boot for more than three seconds. Motherboard displays white CPU debug LED.
I did the basic troubleshooting, checked ram, checked all the cables even swapped in a ryzen 3500 just to see if the other processor was bad and still nothing.
Do I need to roll back the bios?
Motherboard is an MSI mag b550 gaming plus
GPU an RTX 3060 12gb single fan Phoenix I think.
PSU is a cooler master 850 V2 80+ gold
Ram is G.skill 2x 16gb 3200
Edit:
At this Point I have tried
- flashing latest bios
- unplugging everything and plugging it back in
- different ram
- re installing gpu, cpu, ram
Only progress I've made so far is that if there no ram in the system it does stay on and the debug LED switches to the DRAM.
Edited by Rakeboy77
Problem solved
https://linustechtips.com/topic/1568373-help-me-get-booted-please/
Do you have any other ram you can try? The CPU and motherboard might not like this particular kit
Primary PC:
PSU tier list
How many watts do I need?
Please click the "Thumbs Up" on any volunteer's post to thank them if they helped .(lower left, just to the right of My Computer )
18 minutes ago, Rakeboy77 said:
No luck
the motherboard itself may be at fault then
Primary PC:
PSU tier list
47 minutes ago, REHED said:
New or used board?  CPU pins not bent/broken and CPU worked before?  At this point, it would not hurt to try to flash an older bios specified to work with the 3700x using bios flashback.
Bios flashback gave me no new results
3 hours ago, Rakeboy77 said:
Used board
Take it back to the seller. You got a bad one.
