PC making room too hot
dfsgsfa
any Brilliant ideas?
dispite newer tech, tdp hasnt really go down...
no air con of coz
just open 2 windows. 1 in your and one in another on the same level. Also all pc's makes your room hot. Mine also.
PM or DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
Beyerdynamic Tygr 300 R w/ Dekoni Velour as daily driver
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Keyboard > SteelSeries Apex Pro
Mouse > Steelseries Aerox 3 wireless
Mousepad > Pulsar ParaSpeed XXL
VR > Valve index kit
Read this post if you want a "gaming" headset ;)
yes, pc makes the room hot, especially intel's 10th gen.
run a ducting from the pc back pulling the hot air out to your window / outside.
Jual Flexible Duct 4" Non Insulasi - Saluran Fleksibel Tanpa ...
Open doors and windows.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
no air con of coz
Fans?  Ceiling or floor standing?
Can't argue with physics and thermal dynamics.  If your PC makes heat when it does work, that heat is in the room.  How you get it out, or moving faster, is up to you.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
If you cant get rid of the PC's temp, try to look why is your room hot apart from the PC. Check if your wall gets a lot of hours getting sunlight and if you can have an awning or something to help cool the room. The best you can do without spending money is to open your window, your door, and open the window of the room that you have at the other side of the house (with minimal obstruction) to help the air flow trough your house.
CPU: Ryzen 5 3600 @ 4.4GHz 1.2v / GPU: MSI Radeon RX 5700 Mech OC GP (5700XT Bios) @ 2GHz / MB: Asus ROG Strix B450-F / RAM: Kingston HyperX 16GB DDR4 3200MHz CL16 / CASE: MSI MAG Vampiric 010X
It's 45'c+ in summer here, buy a pedestal fan and have it blow in cooler air from some where else, worst comes to worst buy a portable air con second hand and seal the room off. So glad I've got air con now, though it struggles.
Proud owner of a custom water cooled Ryzen 1400. 5800x
What makes the 'room too hot'?  Too hot for a person to be comfortable or too hot for the PC to function?  Most PCs can handle an abnormally warm room without too much detriment, so it's usually the human factor that's the problem.  As such, what I usually do is have a bowl of water and a washcloth, occasionally wipe down my forehead, neck, and back with water and have a fan blowing over me.  Room temp ~43C, PC temp doesn't go above 75C, and the human remains reasonably comfortable.
If I have to explain every detail, I won't talk to you.  If you answer a question with what can be found through 10 seconds of googling, you've contributed nothing, as I assure you I've already considered it.
What a world we would be living in if I had to post several paragraphs every time I ask a question.
9 minutes ago, 7he404guy said:
Room temp ~43C
I get uncomfortably hot at 26°C...
F@H
GPD Win 2
Only way to make room actually cooler is to open window or otherwise make air exchange in the room. Using ceiling or floor fans only circulates same air around. It will feel cooler for you as it moves faster (compare to wind), but temperatures won't change.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Mine does the same thing don't worry.
Red Dead 2 will keep the heat on for me.
I7 9700k- MSI Z390 Gaming Edge AC - Be Quiet Dark Pro 4 - Corsair Vengeance LPX 3200 2X8GB - EVGA RTX 2080 TI Black Edition - WD BLACK NVMe M.2 500GB -  EVGA Supernova 650 P2, 80+ Platinum -Nzxt H500 - Display Dell S2721DGF 27" - Keyboard- Razer Huntsman Mini 60%  - Mouse- Logitech G203  - Headset  Astro A50 2019 Edition - Speakers - Logitech Z623
No. Don't give people bad ideas.
Try undervolting. My GPU generates 40W less when undervolted.
Intel I7-10700KF stock - Noctua NH-D15 - A15+A12x25
Micron Ballistix Sport LT 4133MHz CL17-21-21-40 @1.45v
GIGABYTE AORUS 3090 Xtreme 1905MHz@0.919v/2010MHz@1.063v +900/750 memory clock
Seasonic PX-1000
Lian-Li Lancool II Mesh
gaming kitchen
1 hour ago, dfsgsfa said:
gaming kitchen
Totally put a range hood over the PC!!!
OnePlus:
Other Tech:
u so serius. 🤣
If your room is 45c, your not going to cool your pc down. You have to cool the room first. I highly doubt the TDP of your cpu cause all of that heat. I would think it would be your location, and lack of air movement.
AMD R9 5900X | Thermalright Phantom Spirit 120 EVO, T30,TL-C12 Pro
Asus Crosshair VIII Dark Hero | 4x8GB G.Skill Trident Z @ 3733C14 1.5v
Zotac 4070 Ti Trinity OC @ 3045/1496 | WD SN850, SN850X, SN770
Seasonic Vertex GX-1000 | Fractal Torrent Compact RGB, Many CFM's
To the OP, what are you doing with your computer to make it hot?  Crunching data, gaming for 8hrs or more or something else?
Gaming with my door closed will raise the temp in my room over 10*C easy in an hour. even with the door open will heat it up half that.
Buy a window AC or something...
·Ï¢årµ§·
i7 4790k · 32GB Kingston HyperX · MSI Gaming 5 · ... · 30" HP ZR30W + 27" Samsung 275T · 2x240GB Intel 530 in Raid 0 + 2x1TB Crucial MX500 · Lain-Li X2000F · Antec Signature SG-850 · BeQuiet! Dark Rock 3 Pro · Logitech Z5500 · Win10pro 64bit
its a 10mx3m room, windows on both opposite side, high 20th fl ,connected to a corridor.
3x pc and monitor running, 2 are 9yrs old surving and youtubing, 1 occasionsl gaming.
2 tower fans constantly running, but other rooms are noticable cooler
