I have a folder with 430GB of Files however I just want to keep a backup on a drive incase it ever corrupts or anything.
Does anyone have any recommendations on what drive I should get that has enough storage while also being below $60CAD or near that price point?
I've heard cheap drives usually corrupt but I was interested in seeing if anyone had recommendations that are still low price while being safe.
https://linustechtips.com/topic/1568830-question-for-backup-drive/
1 hour ago, bleedpurple said:
Would something like this be good?
https://a.co/d/ggYFHPC
I've always had luck with WD Blue hard drives, and you can get them DIRT cheap in low capacities right now.
If it's for a desktop, you can hook it up that way, otherwise you'd need a toaster or similar.
