TV as a monitor
iap
why do we don't use LED tv as a monitor
TVs arent build with high refresh rates in mind for gaming since most cinematic movies and stuff are shot at 24fps and dont require high refresh or high response times like a desktop monitor would.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
ah see I must be in the parallel universe where my tv works fine as a monitor. Although there may be a time discrepancy as well me living in 2020
TVs work fine as monitor's as long as you enable "game mode" or whatever the maker decides to call it.
MacBook Pro 16 i9-9980HK - Radeon Pro 5500m 8GB - 32GB DDR4 - 2TB NVME
iPhone 12 Mini / Sony WH-1000XM4 / Bose Companion 20
its getting much better now a days, but this is how it was not to far in the past, say 5 to 10 years. So it still has that stigma around it as not being good when a lot of newer TVs are much better at it these days.
"Black Out"
There is also a price difference.
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
I used to use a 32" TV as my monitor and due to the size of my old desk, it was too close for comfort and sometimes resulted in eye strain. Not fun.
Small TVs only make sense if they cost less for the same sized monitor, and large TVs only make sense if you're using your computer while sitting on a couch some feet away.
With everything said above, I'd say TVs can make awesome second monitors (depending on use). I had a 16.5" TV with a terrible picture quality, but it had all of the ports on the back. VGA, 3 HDMIs, DVI, 3 USBs and other stuff. Small enough to drop on the corner of my desk for Spotifiy and Thunderbird.
Le PC: Gigiabyte Gaming 3, AMD 2700x, Yeston RX 550 4gb, Corsair 16gb, Corsair 450w PSU & Aerocool QS240 case. Linux, Elementary OS.
Whose we?
I've been using a TV as a second monitor for my whole life basically. Don't use it for high refresh rate gaming though, just use it for videos and such.
A TV can make a good second monitor, but always makes a terrible main monitor.
ENCRYPTION IS NOT A CRIME
Been using a TV as main monitor since 2009 or so.
4K ones in the 50" range since 2014.
Only thing they don't have (well, didn't until a couple of months ago) was high refresh rate, but then again that wasn't a thing for monitors until a few years ago either.
F@H
GPD Win 2
I'm using a 40-something-inch TV (from around 2010) as my only monitor for years. You need to fiddle through the menu and figure out the correct configuration, but once that's done, it works just fine. It would be a little too big to have on the desk, so I wall mounted it and put a desk in front of it. I'm pretty happy with the setup. It replaced a two monitor one, but now I just don't need a second screen anymore. The first one is big enough and I'm using a tiling window manager. Also, I never got the feeling that a bigger screen would be nice. It's the perfect size. The only thing I'd want from a new screen is a higher refresh rate and a higher resolution.
(laughs in 1998 imac)
I've been using a 43" 4K Sony TV as my main monitor for a while, but I recently moved to an Asus 43" 4K monitor, primarily for the 120Hz refresh rate.  The difference is fairly significant, but that may be due to the TV I was using.  I never could get a great looking image from the TV. It just lacked a crispness that I found in most monitors.  Unfortunately, I was so used to have such a large main screen that I was afraid I would never be happy with downsizing.  So I went with the Asus ROG Strix XG438Q.  Large and expensive but very nice gaming monitor with FreeSync.  Don't think I could ever go back to TV at this point.  Spoiled.
Sounds like you might have been in 422 downsampled color.
F@H
GPD Win 2
I tried 444 and Game mode but didn't seem to help.  I'm no expert on these things and I googled a bunch of stuff trying to improve it.  I think the problem may have been the TV itself.  Fine when using it as a TV, but not as a monitor.
i have been using a 50" 4k TV as my main monitor for years.  Works fine for the games i play.
Slayerking92
<Type something witty here>
<Link to some pcpartpicker fantasy build and claim as my own>
I am using a 55" LG(B9) G Sync compatible TV as a monitor. I ordered it after watching a LTT video.
It is 120hz at 1080p and 1440p but 60hz at 4k.  Hopefully Nvidia will go HDMI 2.1 and then the TV will do 120hz at 4k.
It also seems to do 1080p and 1440p a lot better than my 4k monitors.
My 28" TN 4k monitors I bought in 2015 did a good 1440p but a washed out 1080p and my 32" VA is only good for 4k.
I am basically an ultrawide gamer since 16:9 even at 32" gives me that cramped feeling.  I don't get that feeling on the TV.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
Modern LCD TV's can be good for gaming, not competitive gaming mind you, but 'casual' gaming. Those with game mode and ability to run 120hz 1080p and even 1440p can be good choices, however in todays market the better TV's that can do this tend to be restricted to larger sizes liek 55"+ which are arguably way to big for most users, as such smaller sizes like 42" which are more usable tend to lack things like 120hz capability.
Ofc while TV's have a better image quality overall, they tend to have better HDR capabilities, and  as they are VA they thus have great contrast, and are almost always way more uniform with far less BLB issues, they do lack certain things 'gaming' monitors focus on more.
Pixel response times for example are not a big focus for LCD TV's, as such even the best LCD TV's (VA panels) will have more 'bluring' than monitors, especialy in dark scenes, and ofc things like Adaptive Sync have only just become available on the newest top end TV's and require HDMi 2.1 which currently PC hardware doesn't support.
Input lag is another issue, though modern TV's with 'game mode' enabled do fair far better nowdays than in the past with 15ms being common place. PC monitor in comparison tend ot hover around 10ms on average, so the difference isnt that big compared to in the past when 50ms in TVs wasnt abnormal.
LCD TVs can make good PC displays, BUT u have to choose wisley, Samsung currently is the leader in TVs for gaming.
EDIT: another thing i forgot to mention. Sub-pixel layout. LCD TV's can sometimes use panels with odd sub-pixel layouts than can cause issues when used as a PC display , for example with text which can end up with fringing issues.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
People do. There's nothing wrong with it. But TVs tend to have slower response times, as well as image processing. This results in ghosting. Unless you go all out on a really decent TV there's an obvious difference between the two. The easiest way to think about the technology inside is cost. Monitors cost more
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
I've been using Samsung TVs since 2010 since they have always had proper support for PC use, even if it was a bit clunky to find out how initially ("HDMI UHD color" to enable 4K RGB444, rename the HDMI source to "PC" to disable overscan ?‍♂️) but once that was done along with game mode results were good. They also calibrate well for photo work with a Spyder style calibrator. Obviously you want the mid to high end models of you care about the image quality, bottom of the barrel is just that regardless of manufacturer.
LG used to be absoulutely terrible, but now they've decided to take that market segment and actually care about having the right interfaces, response times and low latency optimised controllers it seems they're the new king.
F@H
GPD Win 2
Umm, my monitor built in June of 1999 can do 175Hz.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1920x1440@65Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz
Gateway VX900 CRT: 1920x1440@64Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
Some people do.
System specs below
PSU: Corsair CX650M
Yeah but it wasn't an LCD.
It's only recently that manufacturers started caring about making higher refresh rate LCD panels, even though it would have been technically possible before.
F@H
GPD Win 2
3 hours ago, MadAnt250 said:
Some people do.
i am talk about you specs, i5 vs r5 why did you switch and what is the performance different
