Reusing the case from a Fiery Color Controller E-7200
Breadpudding
Go to solution Solved by TVwazhere,
If you do decide to mount directly to the PSU, make sure you're not having any part of the Exposed PCB touching the PSU. Just in case ;)
Couldnt you also just velcro it to the other side of the front panel?
So I decided to try to build the smallest computer possible using parts I already have. I've had success thus far, however I didn't think about the HDD until I tried to put it into the case. Since the motherboard(MicroATX) is bigger than the previous one(FlexATX), it doesn't have any room for the HDD bracket anymore. That's fine because I wasn't planning on having a full-sized desktop HDD, but I still don't have a place to put my laptop HDD. Does anybody have any ideas for mounting it?
Thanks in advance,
        Breadpudding
Discord: Breadpudding#9078
GitHub: https://github.com/cbpudding
Programming Guild: https://discord.gg/7ZVbxXT
If it was my Project, I would mount the HDD to the air flow holes ore drill new holes there. (maybe add some padding to minimise vibration)
Or doublesided Tape on the PSU ^^
i second this one. if it doesn't interfere with any add-in cards you're putting in there this seems to be the best option. you won't be blocking any airflow and since the case stands with the PSU down you won't have to worry about it falling off anytime soon.
it would probably be fine without the tape aswell, just lay it onto the PSU, tough that wouldn't be recommended for long-term use ?
I ve a PC with in HDD just hanging from the top, it still works, as long as it won't hit anything and makes a short you are fine :P
Unfortunately I can't drill any new holes since the entire case is made out of metal(actual metal not the cheap crap that comes in most cases). I'm not sure how I would mount the HDD to the air flow holes but it's an idea worth exploring as long as I leave one of the sides open. As for the double-sided tape I don't have any actual double-sided tape but I can make a loop out of regular tape(not that it'll keep it from vibrating at all).
Just now, RollinLower said:
i second this one. if it doesn;t interfere with any add-in cards you're putting in there this seems to be the best option. you won;t be blocking any airflow and since the case stands with the PSU down you won;t have to worry about it falling off anytime soon.
it would probably be fine without the tape aswell, just lay it onto the PSU, tough that wouldn;t be recommended for long-term use ?
I'm planning on not having any PCIe cards for two reasons:
  1. This is supposed to be a server
  2. The case prevents me from putting any "standard" PCIe cards in without modification
do want to keep it secure to the case because this will be running for long periods of time.
Yeah i third the option to put it on the PSU, just make sure it wont move.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
I haven't thought about velcro. That's a pretty good idea and I might do that.
