RTX 2070 for 1440p?
awpaca
So, been looking for an upgrade for both my monitor and gpu (60hz gtx 980 right now), will the 2070 be able to handle 1440p games for some 3-4 years? Also, does 60fps on 144hz look like the same as in 60hz? will i notice screen tearing? (mainly for e-sports titles like csgo or league)
I have the MSI RTX 2070 ARMOR and I play Battlefield V on Ultra 1440p 60Hz without a problem.
Just want to share some important info, before you get the GPU..
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
not really looking for the Ray Tracing, but the DLSS seems useful, and price drops are not really that common on my country, 2070 almost same price as 1070ti
No! watch the video about DLSS shared in that topic. It's a fail feature. 4K DLSS is like upscalled lower resolution, not even match it, it's even worse than upscalled lower res. horrible
My system specs:
My build logs:
Metro Exodus looks AMAZING with the ray traced lighting on 2080ti though...not sure how it would run on a 2070...probably horrible...but still. :)
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 2 VR
1080p ultra about 100-120 fps
so.. 1440p about 70-80 fps
4k.. eh maybe 30-40 depending on where you are.
PC:
MSI B450 gaming pro carbon ac              (motherboard)      |    (Gpu)             ASRock Radeon RX 6950 XT Phantom Gaming D 16G
ryzen 7 5800X3D                                          (cpu)                |    (Monitor)        2560x1440 144hz (lg 32gk650f)
Arctic Liquid Freezer II 240 A-RGB           (cpu cooler)         |     (Psu)             seasonic focus plus gold 850w
Cooler Master MasterBox MB511 RGB    (PCcase)              |    (Memory)       Kingston Fury Beast 32GB (16x2) DDR4 @ 3.600MHz
Corsair K95 RGB Platinum                       (keyboard)            |    (mouse)         Razer Viper Ultimate
no. games are going so fast graphics wise. this is just not possible anymore. i can maybe give it 2 years but not 3 or 4. heck 2 years is even a stretch. well maybe if you wanne run low settings but you may as well play 1080p then.
PC:
just get a used 1070ti, 1080 or 2060 all good for 1440p
(◣_◢) Ryzen 5 3600,   Aorus X370 K7,   XPG 16GB 3200,   Gigabyte 2070 Windforce Corsair RM650x,   LG 32GK650F-B 31.5" 144Hz QHD FreeSync VA,   Kingston 120GB SSD,   Samsung 1TB 860 QVO,   2TB HDD,   Fractal Design Meshify C,   Corsair K63 Wireless,   Corsair Gaming M65 PRO,   Audio Technica ATH M50x,   Windows 10 ProCorsair H100x 240mm.  (◣_◢)
(◣_◢) Ryzen 5 1600,   Noctua NH-L12S,   Gigabyte GTX 1060 6G,   ASUS Prime B350 Plus,   HyperX Fury 8GB DDR4 (2666MHz - 1.3v),   SilverStone ET550-B,   Kingston 120GB SSD 2TB HDD,   Cougar MX330,   Windows 10 Pro.  (◣_◢)
Just get 2060 if you still want some RT goodies for 60fps 1440p, or go older gen like 1070 Ti/1080/Vega 56.
pick a 2070 not for the dlss or the ray tracing , just for being a 1080 from this year. a 1070ti/1080/2070 can hold 144fps at 1440p very well. I play with a 1070 (not ti) and achieve 160 fps (1440p) in games like apex or 130 fps on pubg without touching settings.
Case: Corsair 760T  |  Psu: Evga  650w p2 | Cpu-Cooler : Noctua Nh-d15 | Cpu : 8600k  | Gpu: Gygabyte 1070 g1 | Ram: 2x8gb Gskill Trident-Z 3000mhz |  Mobo : Aorus GA-Z370 Gaming K3 | Storage : Ocz 120gb sata ssd , sandisk 480gb ssd , wd 1gb hdd | Keyboard : Corsair k95 rgb plat. | Mouse : Razer deathadder elite | Monitor: Dell s2417DG (1440p 165hz gsync) & a crappy hp 24' ips 1080p | Audio: Schiit stack + Akg k712pro + Blue yeti.
A RTX 2070 will work great for 1440p! For e-sport titles like CSGO and League it will easily be able to hit 200+ FPS at highest settings. Though in games like BO4 if you play at high settings you will get 120-150 FPS. In a couple of years the GPU will probably have a hard time to play newer AAA titles at more than 100 FPS with highest settings so then you might have to toggle the settings down a bit.
Corsair iCUE 4000X RGB
ASUS ROG STRIX B550-E GAMING
Ryzen 5900X
Corsair Hydro H150i Pro 360mm AIO
Ballistix 32GB (4x8GB) 3600MHz CL16 RGB
Samsung 980 PRO 1TB
Samsung 970 EVO 1TB
Gigabyte RTX 3060 Ti GAMING OC
Corsair RM850X
Predator XB273UGS QHD IPS 165 Hz
iPhone 13 Pro 128GB Graphite
cool but the highest he goes is the extreme preset withouth raytracing...it clearly say on the intro image RTX & DLSS OFF
With ray tracing you're lookint at 50/60FPS at best at 1080p (and this is with the disgusting DLSS enabled mind you)... and probably 30/40FPS at 1440p and 4K is a slide show..here:
Are you sure you dont touch any settings?  I have a 1070ti (overclocked) and play Apex on 1440p, havnt touched any settings and pull 115 FPS max.  And your pulling this with a 1070 (non Ti) on 1440p?
Yep, I can post you a screenshot later , from 140-160
well i did mean the fps wise non rtx. rtx is just not good with something like a 2070.
and extreme is the highest setting. so this is worsed case scenario (besides rtx).
So the rtx 2070 can do quiet allot. but its pretty dissapointing since the rtx 2060 overclocked performs around a 2070 stock. so the 2070 is a bit of a joke.. it deserved allot more performance thats for sure. i mean get a 350 card.. oc it and you will have a 550/600 euro card. how dumb right?
cpu oced to 5 ghz? or close?
PC:
Then why you quoted my post where i was talking about RTX ray traced lighting looking amazing on a 2080ti and probably ran horrible on a 2070...
i mean, i know the RTX 2070 can run metro exodus plenty well...so long as you don't use raytracing:
The hell you talking about?!
The RTX 2070 is roughly 25% faster than a 2060...can you overclock a 2060 by 25%? and if you can...guess what: you can overclock a 2070 as well. This argument doesn't have ground to stand on...
The RTX 2070 has 2304 cuda cores and the 2060 only has 1920 cuda cores...that's a 20% difference right there...and the 2070 has more memory. The RTX 2070 is a lot more powerful than the 2060...now if it's worth the increase in price over a 2060 is up to you to decide.
https://gpu.userbenchmark.com/Compare/Nvidia-RTX-2070-vs-Nvidia-RTX-2060-6GB/4029vs4034
I was in the same boat as you about a month ago. I looked at the cards performance wise knowing how often I upgrade and I decided to go with the rtx2060 and a 1080p 144hz monitor.
I didnt want to spend 2080 or 2080ti money on the card so I stayed at 1080p and went to
144hz.
For 1440p I wouldn’t go below the 2080, I don’t use ray tracing at all, I have no interest in sight seeing because I play mostly shooters where I’m looking for people not lightrays bouncing off of stuff
13700k- Pa120
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Gigabyte Rtx 4080
Fractal Ion 2+ 860watt platinum
Be quiet 500dx
Samsung Neo G7 32 inch + AOC Q27G3XMN
Xbox series x
No it isn't. The 2070 is like the 1070 ti vs the 1080, the 1080 doesn't make much sense with the price difference between the two cards.
Quote
When put head to head against the RTX 2070 we see that the RTX 2060 was up to 16% slower and that’s a worst case scenario. Meanwhile there were a handful of titles where the margin was under 10% and overall this meant the RTX 2060 was on average only 11% slower at 1440p. You have to wonder why anyone would spend over 40% more on a graphics card that’s not even 15% faster.
Source:
https://www.techspot.com/review/1781-geforce-rtx-2060-mega-benchmark/
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
lol people using userbenchmark as a gauge for actual gaming performance. Look at game benchmarks dude. 2070 is nowhere near 25% faster than 2060. It averages around 10-15% faster depending on the reviewer. And hell let's suppose you're right (Which you're not) the 2070 still doesn't make sense because it costs 40% more.
Anyways to summarize, nope. Not much more powerful. 15% more performance for 40% more cost is dumb. Nobody should buy the 2070.
edit: Also come on mate you know better than to try to extrapolate relative performance between cards based off of core counts. GTX 1080 has 2560 cuda cores, 1070 has 1920 cuda cores. That means 1080 has 33% more cuda cores. 1080 is nowhere NEAR 33% faster than 1070. It's like MAYBE 25% faster. So that means there's a 32% relative delta between actual performance and predicted performance. Let's run that through the 20% higher core count and hey look, 2070 should be around 15% faster than 2060, which lines up with the actual numbers people have found. Go figure.
Main System: EVGA GTX 1080 SC, i7 8700, 16GB DDR4 Corsair LPX 3000mhz CL15, Asus Z370 Prime A, Noctua NH D15, EVGA GQ 650W, Fractal Design Define R5, 2TB Seagate Barracuda, 500gb Samsung 850 Evo
Secondary System: EVGA GTX 780ti SC, i5 3570k @ 4.5ghz, 16gb DDR3 1600mhz, MSI Z77 G43, Noctua NH D15, EVGA GQ 650W, Fractal Design Define R4, 3TB WD Caviar Blue, 250gb Samsung 850 Evo
as others put it.. just exactly that. The rtx 2060 oc is so close to a 2070 at at least here in the netherlands.. around 200 cheaper. that its stupid. yeah you can oc the rtx 2070 but that doesnt come anywhere near a 2080. so its stupid...
PC:
Honestly it was never greater than 10fps difference if you try maxing settings, I also defend that you either go 2060 or 2080, the 2070 is already too expensive for too little gain.
Personal Desktop":
Luna, the temporary Desktop:
yeah sadly i had already bought an msi gaming z (2070) pre 2060 release. xD
PC:
