Try and fix handwriting or try to learn with left hand?
Solved by divito,
Mine is actually similar to techswede's sample, if even a little worse, as far as readability goes. This will also depend on whether I'm writing quickly for notes or actually trying to write well.
I don't think yours is all that bad; while it has a childlike quality, it's perfectly readable. If you want to improve on it, simply take your time when you write. I think in situations where you're writing fast, there's not a lot of hope in changing your habits for the style; but in situations where you have time, it's certainly possible to slowly train yourself for better quality.
For me, I've given up long ago on fixing my chicken scratch. But then again I'm old.
