Will a Noctua NH-D15S fit?
TL;DR: the D15S has 66mm of RAM clearance, and since Flare X5 sticks are 33mm tall, it'll fit just fine. If you get the non-S version, that only has a standard RAM clearance of 32mm, so you'd have to raise the fan up 1mm in order to get everything to fit, and given that you have 15mm of clearance between the cooler and the side panel at stock (the NH-D15 is 165mm tall and the Lancool 216 can fit 180mm coolers), that extra mm you need to raise the fan up is effectively irrelevant.
Not that I'd exactly recommend the NH-D15 anyway, it's been outclassed by coolers much cheaper than it at this point. Something like a Deepcool AK620 or Thermalright Peerless Assassin is going to be half the cost and slightly better performance, plus they both have better RAM clearance.
