Read everything below if you plan to answer
So I'm going to college this fall, and I'm planning on building a PC in an old Dell case. When I do this I want the power button, Power LED, and HDD indicator to be able to work as intended, so as to make it seem as if this is just a normal Dell computer, but along the way I ran into a few problems.
First of all, it uses an all in one custom connector for the power button that nobody has documentation for on the pinout, that's fine I'll do it myself. I'll figure out each wire.
So I spend the time one by one testing pins with my test bench until I get the button itself working
The power LED
And the HDD indicator all working
Except one thing is bothering me: The power LED never turns white like it should, it stays orange, but there are no more pins I could possibly hook into on this 6 pin connector (really 9 pin but 3 are not populated)
So I guess I'm really just asking on here if anyone has the very niche knowledge to help me solve this problem and help me make this disguised PC build a little more stealthy when I finally get all the parts in to put it together properly.
https://linustechtips.com/topic/1568400-dell-case-power-button-shenanigans/
you shur is sapos to go white? only thing i can think of is different voltage per led.
so is that like orange standby and white power on?
Edited by thrasher_565
Yep. It's supposed to go white, I found videos of it online with the original Dell motherboard inside and such, orange with the original Dell motherboard usually seems to indicate there is power but but there is some kind of  hardware failure, so I'm wondering what I'am failing to replicate. I'll have to look into it more in the morning.
hmm ya seems compacted for a dell. my guess is the power is  variable thats how it would no. its not like things had a smart chip in it to tell it what to do. (as far as i no...) you might be able to put some small voltage thow it and push the button and see what it dose on a multy meteor but im guessing its a momentary switch? and with out more data wires only thing i can think of. a normal mb wont have variable voltage at lest for the headers.
What happens if you flip the power LED polarity?
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
4 minutes ago, Nesy said:
It just doesn't turn on. Which makes sense, LEDs are diodes.
I was under the impression that the two colors were reverse parallel LEDs (one color one polarity, other color other polarity).
Network:
They're on to something, though. The Optiplex 7010 has two LEDs 'facing' opposite directions, so all they have to do to change the color on those models is reverse the polarity of the power LED pins.
https://www.dell.com/community/en/conversations/vostro-desktops/vostro-3470-mainboard-pinout-for-power-switch-connector/647f9bedf4ccf8a8defeee13
You might have to take the front button panel out of the case and see how it's wired on that end.
So I figured it out
The answer was a different voltage like thrasher suggested but I accidentally gave it too much and it immediately burned out. It shows orange at 3.3v and I gave it 5v. For a couple seconds it was white before it turned off and wouldn't come on again. Probably should have done smaller increments up.
My own fault but I'm sure I could put my own light into there so I think I'll just do that. One that glows white lol. Probably what I should have done in the first place I just wanted to see if I could do it with what was already there.
Thanks for the suggestions ya'll, pleasure speaking with you all.
