Laser Razor from Skarp
jos
Skarp Razor is replacing blade with a laser and plans to make it available to everyone. Skarp created a razor that doesn't cause irritation, shaves smoothly and can help reduce waste. Wavelengths of light had been discovered that cut through dark hair but not light or gray hair, so it wasn't until 2009 that he found a wavelength that could cut any color hair. It doesn't emit UV, and the power of the laser is too low to cause damage. Most importantly, the laser doesn't enter the skin or cause complications that can happen from traditional laser hair removal. Skarp can be used with water, but it's not necessary, which means users can also reduce the amount of water they use when shaving and lathering. The laser has a life of 50,000 hours and is powered by a AAA battery.
Gustavsson has been working in the medical and cosmetic laser industry for three decades. In 1989, he invented Intense Pulsed Light, still the preferred method of hair removal and dermatology treatments today.
That is cool, I guess in a way it is a competition for dollar shave club.. no more razors needed.
Source: http://mashable.com/2015/09/28/skarp-razor-kickstarter/#QpsDseZAgmqi
https://www.kickstarter.com/projects/skarp/the-skarp-laser-razor-21st-century-shaving?ref=popular
Does it produce a smell?
No. Because we're not actually burning the hair, it doesn't produce a burnt hair smell.
Is it safe?
Yes, the laser is low power & eye safe
Can I shave at normal speed?
Yes you can. You don't have to shave at slow speeds! You'll even finish a little quicker as you won't have to lather up!
So many of them have a beard rofl.
Also, who doesn't love the smell of burnt hairs in the morning.
Also that doesn't sound even remotely realistic.
so, would you call it a ... Lazor
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
A 50k hour life on the laser would mean a lifetime of usage for me, since I only shave like once a month. Beards are superior in every way to a clean shave. Unless you look like a hobo with one.
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
itll smell burned and ive you tilt it wrong you burn yourself
i9 11900k - NH-D15S - ASUS Z-590-F - 64GB 2400Mhz - 1080ti SC - 970evo 1TB - 960evo 250GB - 850evo 250GB - WDblack 1TB - WDblue 3TB - HX850i - 27GN850-B - PB278Q - VX229 - HP P224 - HP P224 - HannsG HT231 - 450D
well from the video it looked like the laser actually only turned on when it became in contact with the hair so that could be very true depending on how its done.
50,000 hours for a laser than can burn hairs on a single AAA battery? Dude, no way.
so ive i push and some skin lifts up and a hair is on the same level, i would get either burned or it wouldnt work, right?
i think it simply is harmless to skin, when the guy was holding just the laser itself he it was clearly on and was able to rub it on his skin without burns
it looks ridiculously expensive and probably uses a fair bit of energy. if you want to reduce waste just use a traditional razor knife or safety razor and recycle the blades.
There is stuff like pulsed light therapy that would require a few treatments over a month, a bit of cash, but you would almost never need to shave again.
I rather do that and never risk looking like a disgusting hobo or manchild faglord with a beard which serves as a home for many.
I'm calling bullshido on that right away
 pulsed light therapy technology was invented by the same guy who made this
It means that laser last for 50000 hours before breaking, not that one charge would.
Lol, Skarp literally translates to Sharp in Norwegian.
I love puns
It would be nice if they put a demonstration video rather than just a "theoretically this works" video.
Either way, would be cool if if actually works
Home is where the heart my desktop is.
Dollar Laser Club
Over $1 million pledged of the $160,000 goal.
I think I'll wait for it to come out before making a decision.
Quote
From the Kickstarter page Q/A section.
"The Skarp Razor uses a single AAA that will last about a month with normal use."
"The laser has a life of 50,000 hours."
I'm not an audiophile, I'm just really picky about my music... and my headphones... and my speakers... and my microphone. Other than that, I'm totally not an audiophile.
okay. that's better. still don't think the smell will be something I would want.
Apparently ..The laser is not burning the hair and make smell.. it is just affecting some molecules in hair to make cutting...I dont know how that works..
It seems like I might finally be clean shaven. Goodbye beard...you've served me well but I never actually liked you...was just too lazy to shave you.
