Is there a way to rip out a laptop touchpad and make it work with a pc?
Snickerzz
ehh? :D
don't ask why, idk xD
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
umm no the controller is actually on the MB not the trackpad. Just buy on of the couple bluetooth variants available
Nop :(
yes but i figured if i could rip one out of a laptop it wouldnt cost me anything, plus i would have accomplished something xD
Edited by WoodenMarker
Making language more kid-friendly
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
Yes and no. You COULD in theory if you spent a lot of time on it but it would be a hell of a lot cheaper and easier to just buy one
If i could use  my macbook pro touchpad's multitouch gestures on windows i would be so happy
Get their touch pad and use it in windows? They make a Bluetooth one.
I know i have the magic trackpad, but good luck with multi touch gestures
Driver?
Driver?
i doubt they even made one for windows.
not to mention we'd need to make sure windows supports the complexity of th interactions
Im sure it could if apple really wanted it to.
yep.
but it's been years of complaining.
quite simply, they don't want to make a tool that would make windows mchines better
If you did that it would cost you a perfectly good laptop
i have 3 that are poop xD
Windows 8 does have its own set of multitouch gestures, but yeah, it's not quite the same.
You're and your are not the same. Neither are their, there, and they're. Defiantly and Definitely are definitely not the same. Definately and Rediculous are not words, and you should feel bad for misspelling them. If English is your first language, you don't have a learning disorder, and you get any of these wrong, you are making the entire forum slightly dumber by doing so. Please take the extra three seconds to type properly, and have a nice day.
According to some Linux advocates you JUST write your own. :wacko:
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
you could toss mouse without borders onto your laptop and make it control your main rig. but if you are willing to destroy your laptop for the touchpad it sounds like the lappy is fooked.
