Laser mouses tend to have acceleration and prediction built in... not good if you are playing FPS games and you don't aim where you think you are. Down to a laser "guessing" where you want to go the same 1CM movement could aim you to a different place. (not by a lot I might add but enough to bother pros)
Stick to optical DPI is just a gimmick, If you play FPS games at over 1500DPI you are doing it wrong!
Quack 🦆
https://linustechtips.com/topic/133157-optical-vs-laser/#findComment-1771744
I know DPI is just a gimmick I have a mouse with a 8200 dpi sensor or something and I play at 1000 dpi, I'm just wondering because I want to buy a new mouse and I want to know if this is really an important factor, I guess it is
MSI Z87-GD65 - GTX 760 DirectCU II - i5 4670k @4.0GHz - 16GB Corsair Vengeance @1866 MHz
https://linustechtips.com/topic/133157-optical-vs-laser/#findComment-1771751
Ok. But is it really that different that you would notice immediately?
Put it this way, I get very pissed off by monitor input lag (vsync on) but I don't notice a difference with laser mice. If you have a specific mouse in mind but you are unsure solely because it is laser, just get it you will be fine.
Rig: i7 2600K @ 4.2GHz, Larkooler Watercooling System, MSI Z68a-gd80-G3, 8GB G.Skill Sniper 1600MHz CL9, Gigabyte GTX 670 Windforce 3x 2GB OC, Samsung 840 250GB, 1TB WD Caviar Blue, Auzentech X-FI Forte 7.1, XFX PRO650W, Silverstone RV02 Monitors: Asus PB278Q, LG W2243S-PF (Gaming / overclocked to 74Hz) Peripherals: Logitech G9x Laser, QPad MK-50, AudioTechnica ATH AD700
https://linustechtips.com/topic/133157-optical-vs-laser/#findComment-1771847
Let me recomend you the logitech g602. I have it and love it. It is optical. It feels great in construction, materials, shape, number of buttons, and button placement.
https://linustechtips.com/topic/133157-optical-vs-laser/#findComment-1771900
Is it noticeable? To some. Is there a difference? Absolutely.
When we're talking about precision in games like FPS, you might be moving your mouse across half the screen within half a second and so you might not notice the acceleration cause your cursor to overshoot by a few pixels, but it could be the difference between hitting your target and missing.
https://linustechtips.com/topic/133157-optical-vs-laser/#findComment-1771951
do you want to fight with your mouse and have it do what you didnt intend it to do? go for laser
do you want your mouse to behave exactly as its supposed to and do only what you want it to do? go for optical
Specs of my PC:
CPU: AMD FX 8350  Motherboard: Gigabyte 990XA UD3  GPU: Gigabyte GTX 770 Windforce 2GB  HDD: WD Green 2TB SSD:  Corsair Force GT 120GB SSD RAM: Corsair 8GB(2X4) PSU: CoolerMaster G650M
https://linustechtips.com/topic/133157-optical-vs-laser/#findComment-1772452
I recently switched back to an optical mouse (NAOS 7000) after years of several different lasers. The difference was immediately noticeable because I was having so many issues with the laser mouse (Naga 2014). Anything with moderate bass playing through my desktop speakers would cause vibrations to disrupt the sensor and seemingly shake the cursor. Still getting re-used to the nature of the optical mouse, but it's at least rock solid while music is playing. Perhaps this was a specific issue to my laser mouse, or how it liked (or disliked) my mouse surfaces. Issues aside, it did feel like I'd often be fighting the mouse to get it where I intended as ManOfDisguise mentioned above.
Not sure if it's just a lens/reflector technology that could successfully be applied to an optical mouse or not, but Logitech's Darkfield devices are pretty sweet and they're laser. Anywhere Mouse MX works well on my glass desk, or jeans, or skin.. I use it with my laptop, not for gaming.
https://linustechtips.com/topic/133157-optical-vs-laser/#findComment-1772699
Laser is much more sensitive, but what I'm interested in that no one has pointed out yet is that the biggest selling point of laser is durability, an optical mouse stops working because something gets in it or it falls etc.
It's analog vs digital, optical being analog and laser being digital, sure it's more accurate to aim with in FPS with an optical one, but I personally play great CS:GO with a laser mouse and the difference really is negligible, if you get used to a laser for years then you will learn to move somewhere else to actually be at where you wanted it to be. SImilar to a sniper rifle, you aim at the blank grass, but due to calculating air resistance, etc, you hit the guy in the head.
tl;dr: Choose a mouse based on looks and comfort, THEN check if it's laser or optical, want extreme precision in FPS? But with risk of it not working due to an accident, get optical.
Care little about minimal differences, like sensitivity and higher life expectancy? Get laser.
https://linustechtips.com/topic/133157-optical-vs-laser/#findComment-1773019
That's a new one. You sure you aren't thinking of ball mice?
https://linustechtips.com/topic/133157-optical-vs-laser/#findComment-1773076
Every laser mouse I've owned have had problems with erratic movement when dust or hair or something gets in the sensor. Never had the same issue with any optical mouse.
https://linustechtips.com/topic/133157-optical-vs-laser/#findComment-1773191
