Help Super Ultra Fast ASAP
SirReno
is there a way to connect 4 HDMI's inputs and have a single output, and when connecting it to a computer have the 4 screens of the inputs
what we are looking for is to get in a single hdmi the 4 sources, or what options do i have in order to achieve this?
I need an answer or options ASAP
Prices dont matter
Wow, that was a boy who cried wolf moment.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
no, cause what i need is to get the 4 sources on the pc at the same time
PCs don't have video inputs. You will need capture card for that, and professional grade of that. Or some box in between to transcode image stream to single input.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
All I can think of are the monitors that do picture in picture (splitscreen) mode. They aren't exactly cheap though.
I DON'T THINK I CAN ANSWER FAST ENOUGH AAAAAAAAAGH!!!!
Primary PC:
The example that they have me is:
Imagine you and your friend want to play xbox/playstations (whatever) each of you will have a camera, and all of those inputs (2 cameras and 2 gameplays) need to be shown in the stream with a single pc
All of those at the same time? Or have the ability to swap between them?
Capture cards it is then. Then record the camera footage through webcam or on camera locally.
Then add it together in post.
at the same time
the cameras that they are requesting use hdmi for some reason
at the same time
Okay, then yeah what Golden said above. You'll need either a 4 input capture card if all sources are using HDMI or a 2 input card + two usb webcams
yeah but what device/interface supports the 4 hdmis?
Keep in mind it needs to handle 4 inputs and you will need something to encode the footage.
Professional grade capture card. Start looking at what Elgato, Avermedia and Blackmagic have to offer.
Something like avermedia ce314-hn would probably do the job, prices are high though
do you know where can i get it that ships internationally?
Couldn't find this one but you can get a magewell one @Warlockben recommended on amazon https://www.amazon.com/dp/B0178DV064/ref=psdc_6795230011_t1_B07BFBYCQ1
damn it, even with the fastest shipping method, it will arrive late
Sounds like a lack of planning on someone's part, then
ikr? its just that they came here with this idea/proyect and told us to have a demo for wednesday, which is fucked up tbh
