Noctua fans loud AF
By
AndeSandwich
in Cooling
in Cooling
Solved by WoodenMarker,
1 hour ago, Bananasplit_00 said:you might have to send the entire cooler back to them though
Probably not. It should just be the fans if anything at all.
@AndeSandwich Have you tried running the fans off of the heatsink and seeing the noise continues? Are you sure that the noise is from those fans and not something else? Does stopping the fans with your hands stop the noise?
Featured Topics
Avallyn ·
2
me255 ·
Posted in New Builds and Planning8 -
Alienized ·
kasdashd ·
Posted in Folding@home, Boinc, and Coin Mining1 -
4
