Sony a90k 42 movies and anime
Solved by saintlouisbagels,
21 hours ago, tom1828 said:Appreciate oleds have issues due to the pixels responding too fast
2 hours ago, tom1828 said:They stutter due to near instantaneous response times
Cite your sources.
You can overdrive an LCD panel which can cause inverse ghosting.
Aside from that, OLEDs are the best panels for pixel response.
21 hours ago, tom1828 said:Any issues during slow pans or when the action gets frantic?
Movies are shot in 24fps, so you will get choppy pans no matter what.
You can enable motion smoothing "opera effect" if you don't like 24fps movies and 30fps television.
OLED panels have instantaneous pixel response... so frantic action is not a problem
