choosing PSU for i5 8400 + GTX 1060 6gb
help me choose the best PSU for my i5 8400 and 1060 6gb
1.seasonic focus plus platinum 650w
2. corsair rm 650x
i'm using nzxt s340 elite case, will my PSU fit on my s340 elite?
next question, i'm planning to use air cooling which one better?
1.deepcool gammax gt rgb with noctua nt-h1 thermal paste
2. cryorig h7 quad lumi with cryorig thermal paste
thankyou and sorry for my bad english
I would get the seasonic PSU and either one of the coolers will be fine. Difference in thermal paste won't really affect much.
Get whichever is cheaper, both are good units. You won't need 650 btw, a 550 would still be plenty for that system.
PC - CPU Ryzen 5 1600 - GPU Power Color Radeon 5700XT- Motherboard Gigabyte GA-AB350 Gaming - RAM 16GB Corsair Vengeance RGB - Storage 525GB Crucial MX300 SSD + 120GB Kingston SSD   PSU Corsair CX750M - Cooling Stock - Case White NZXT S340
Peripherals - Mouse Logitech G502 Wireless - Keyboard Logitech G915 TKL  Headset Razer Kraken Pro V2's - Displays 2x Acer 24" GF246(1080p, 75hz, Freesync) Steering Wheel & Pedals Logitech G29 & Shifter
ok thanks for your help bro! God Bless You ;)
because im using 4 140mm fan,amplifier,USB hub 3.0, do u think 550w still enough?
my plan using platinum because i read it from youtube, platinum make efficiency better, and then make electricity payment lower
(sorry for my bad english bro, lol)
Not sure what you mean by amplifier (like a usb headphone dac and amplifier?), but those are all really low rated components. Nothing to worry about.
Main rig: i7 8086K // EVGA Z370 Micro // 16GB Gskill TridentZ 3200Mhz CL14 // Sapphire Pulse RX 7800XT// a variety of noctua cooling // Corsair RM750x v2 //  Fractal Meshify C
Secondary rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Cooler Master V650 // Fractal Meshify C
Audio setup: Audient iD4 // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II // Audio Technica M50x // Sennheiser Momentum 4
yes that's what i mean, ok but how about platinum and gold efficiency? is there any different on electricity payment??
The RMx is a better unit methinks, 550w is plenty. The efficiency rating on the FOCUS is mostly there for looks, it's not (much) better than a focus plus gold (which is definitely worse than an RMx)
Just some bapo nerd from 'Straya
PCs:
Main: i7 7700K (5GHz 1.4V) | ASUS GTX 1080 TURBO | 4x8GB Corsair Vengeance 3000MHz (3200MHz CL14 1.365V) | ASUS PRIME Z270-AR | Thermaltake SMART 750P | Coolermaster Seidon 240P | Acer Predator X34 (34" 1440p144Hz GSync IPS)
Secondary: i5 3570K | Intel HD4000 (RIP Sapphire HD 6850) | 2x2GB + 1x4GB Kingston 1600MHz | ASUS P8Z68-V LX | Corsair CX650 | Coolermaster Hyper D92 | Sony Bravia VPL-VW80 (108" 1080p60Hz projector)
Laptop: i7 7700HQ | GTX 1060 6GB MXM | 2x16GB SODIMM | OEM Acer Motherboard | 17.3" Screen (1080p60Hz IPS)
iMac: Core 2 Duo T7400 | ATI Radeon X1600 | 2x1GB 667MHz DDR2 | 20" Screen
so if 550w enough for my rig, i have 2 choice
1.bitfenix whisper 550w gold
2.corsair rm550x
which one better??
2.corsair rm550x
which one better??
They're both good enough for me to not care about whichever one I'd put in my own system. Get the cheaper of the two :)
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
8 hours ago, Altruist said:
i have the same main components, this system will consume about  200watts, @STRMfrmXMN
You are correct sir.
2.corsair rm550x
which one better??
WhisperM, it uses the same platform as the RMx 2018 revision, but uses an FDB fan instead of the Rifle bearing fan used in the RMx
PCs:
How about bitfenix whisper and seasonic focus gold? All with 550w
Ok thanks a lot bro! God Bless You
The Focus or Focus Plus? Compared to the Focus Plus, the Whisper M is quieter past a ~200W load, it has multi rail and it's probably easier to find custom cables for (it's compatible with the Corsair Type 4 cables). If you're comparing it to the semi modular Focus Gold, it's no question, the Whisper M.
The Focus Plus has a semi passive mode (the Focus does not) and it has a longer warranty (10 Vs 7 years on the Whisper M and Focus).
Sorry, i mean focus plus gold, which one better overall? Bitfenix or seasonic?
Fan is maybe 5W, amplifier at most 20W, USB hub 1W, no
Platinum isn't much.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Ok
But how about 550w gold? Bitfenix whisper or seasonic focus plus?
23 minutes ago, EnterClassroom said:
Ok
Whisper M, unless you can get the BeQuiet Straight Power 11 the Whisper will be one of, if not the best gold rated PSUs available.
PCs:
51 minutes ago, EnterClassroom said:
Ok
Whisper M all the way.
Full Specs
Helios EVO (Main):
Delta - Laptop
ok thanks bro, God Bless You
Ok thankyou and God Bless You ;)
