Skylake CPUs in some cases more than 50% slower than the ealier generations
Anghammarad
This is from a Blog entry from A. Kraus: https://aloiskraus.wordpress.com/2018/06/16/why-skylakex-cpus-are-sometimes-50-slower-how-intel-has-broken-existing-code/
In short, the architecture has changed so that certain code causes the perfomance break in the current skylake cpus.
Some Programs seem to run 50%
pause
The problem regarding the massive performance loss lies in the pause command interpretation. This for short.
Quote
CPU Pause Duration In ns
Xeon E5 1620v3 3.5GHz 4
Xeon(R) Gold 6126 CPU @ 2.60GHz 43
Due to this change you can see the time spiking up more and more every time the code goes for a pause cycle.
Intel says they implemented the change due to the massive instruction loads todays processors may receive and that PAUSE is now more vital then ever.
Quote
The .NET enviroment already has a fix/update at hand, which may not reside on all systems hit by that issue.
The full extend of the search why a new cpu runs code at only half the speed than to the previous version, while the rest stays the same is a really good read.
Have fun reading.
My opinion with this... well this might hit more systems than the so called y2k bug due to well code getting interpreted differently. If this is not known, no workaround done, well you wonder why your new highend hardware underperfoms that much against its predecessors... So due to the Impact this would have to be communicated better by Intel, so that fixes or workarounds in the code interpreter for all the languages could be accessable in time.
Cheers
Ang
Edited by Anghammarad
Because it was needed... me slacker...
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
Pretty interesting issue, wonder what made Intel increase the pause delay
Edited by Crunchy Dragon
Builds:
A bit too abstract for me. Are there end user examples which show a big difference in performance? Or is this a case of "if you do only this thing it is a lot slower"?
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
In short, every program whos code uses the "Pause" function, will slow down a Skylake system until it has gotten a workaround installed, like for .NET the released fixed version.
But software today is written an many different languages, not only .NET... for example java, c#, e, c++, assembler, cobol, comal, basic, python, pearl, only to name a few...
Main System:
The question remains, what software is noticeably impacted? For example, are there any examples where IPC of say Haswell is higher than Skylake? Also the linked article was written around Skylake-X/Xeon, does this apply to Skylake mainstream too? What about Kaby Lake, Coffee Lake?
What I'm trying to understand is what is the real world impact of this? Skylake has been out for nearly 3 years now. If there was anything approaching 50% loss in applications compared to previous generations, someone would have noticed long ago.
Yes it is a feature in the whole skylake architecture. from mid 2017 on.
IRRC there were some cases here on the forum where people asked why their new system is giving such a bad performance... This could be the impact of this "feature".
Main System:
Skylake was launched summer 2015. Vague performance claims don't cut it. Where is the evidence this impacts in practice? That's not to say it doesn't or can't have any impact, but in nearly 3 years since it came out, if there were any major performance regressions you'd think someone would have mentioned it long ago.
I think we're looking at non gaming aspects here. They literally multiplied the pause time by more than 14x times the cycles and that certainly does something. I have no idea why they did this, there's certainly a good reason, but nice of them to break existing code, which imo should never be done unless absolutely necessary.
From my understanding, it's up to 140 cycles, but it can be specified lower. I think the problem comes with programs expecting a max time of somewhere around 10 cycles and maybe not specifying a number of cycles? So were looking at a problem that will be patched, but has to be patched per program and per platform they use I think, so it could be a small problem basically forever for some things that dont receive updates. I also think that some programs cannot specify the number of pause cycles for some sort of security reason.
I believe Spinlock functions loop this wait time basically, which..it's waiting on something from another thread to finish? But more threads multiplies the problem, that is for sure.
But i could really be wrong about all of this, my understanding is very weak and from memory.
The blog mentions that MS may have had some advanced warning based on server 2016 not having the problem.
muh specs
Gaming and HTPC (reparations)- ASUS 1080, MSI X99A SLI Plus, 5820k- 4.5GHz @ 1.25v, asetek based 360mm AIO, RM 1000x, 16GB memory, 750D with front USB 2.0 replaced with 3.0  ports, 2 250GB 850 EVOs in Raid 0 (why not, only has games on it), some hard drives
Screens- Acer preditor XB241H (1080p, 144Hz Gsync), LG 1080p ultrawide, (all mounted) directly wired to TV in other room
Stuff- k70 with reds, steel series rival, g13, full desk covering mouse mat
All parts black
Workstation(desk)- 3770k, 970 reference, 16GB of some crucial memory, a motherboard of some kind I don't remember, Micomsoft SC-512N1-L/DVI, CM Storm Trooper (It's got a handle, can you handle that?), 240mm Asetek based AIO, Crucial M550 256GB (upgrade soon), some hard drives, disc drives, and hot swap bays
Screens- 3  ASUS VN248H-P IPS 1080p screens mounted on a stand, some old tv on the wall above it.
Stuff- Epicgear defiant (solderless swappable switches), g600, moutned mic and other stuff.
Laptop docking area- 2 1440p korean monitors mounted, one AHVA matte, one samsung PLS gloss (very annoying, yes). Trashy Razer blackwidow chroma...I mean like the J key doesn't click anymore. I got a model M i use on it to, but its time for a new keyboard. Some edgy Utechsmart mouse similar to g600. Hooked to laptop dock for both of my dell precision laptops. (not only docking area)
Shelf- i7-2600 non-k (has vt-d), 380t, some ASUS sandy itx board, intel quad nic. Currently hosts shared files, setting up as pfsense box in VM. Also acts as spare gaming PC with a 580 or whatever someone brings. Hooked into laptop dock area via usb switch
Okay so my questions, as someone with an i3 6100...
1) What should I/can I do as the end user to eventually fix this? Anywhere specific I should keep an eye out for a fix being released?
2) As mentioned earlier, is there any hard evidence of this affecting real-world performance?
3) What mainstream applications are affected by this?
A society's accepted views of the world surrounding said society is both the making and undoing of society itself.
“While one person hesitates because he feels inferior, the other is busy making mistakes and becoming superior.” - Henry C. Link
As someone with 7 systems that are Skylake or newer, I'm currently doing... nothing about this. This is even lower on the radar as far as I'm concerned than the Spectre/Meltdown fixes.
Sounds more related to Skylake-SP to me given the change to mesh architecture and all the examples being Xeons. I would Imagine it has to do with the mesh change and the reconfiguration of more L2 cache and less L3 cache, pausing and ignoring the OS might be better than dumping data out of the cache then having to go back to ram and reload to cache again then try again.
It sounds like this is just skylake specifically but can anyone confirm that?  Or is this potentially an issue for skylane and anything newer (kaby, etc.)?
The PAUSE instruction that this slide deck is talking about is for a thread to notify the CPU that it's going to do a spinlock type of wait. For those that don't program, a spinlock is the thread doing nothing until some resource is free. Like if a thread is waiting for the hard drive to be free because someone else is using it, it does this:
while (hard_drive_available == false):
  do_nothing
Alternatively, there's always the Wikipedia page on the subject if you want to read it.
According to a Stack Overflow post about what the PAUSE instruction does:
Quote
PAUSE notifies the CPU that this is a spinlock wait loop so memory and cache accesses may be optimized. See also pause instruction in x86 for some more details about avoiding the memory-order mis-speculation when leaving the spin-loop.
PAUSE may actually stop CPU for some time to save power. Older CPUs decode it as REP NOP, so you don't have to check if its supported. Older CPUs will simply do nothing (NOP) as fast as possible.
So this additional latency is likely a power saving measure. Instead of waking up 10 cycles later to check something, it waits up to 140 cycles later.
Note that spin locking tends to be looked down upon in multithreaded programming because it wastes CPU time. It has its perks, in that it's simple and keeps the thread on the CPU, but unless you know the time to acquire the lock is extremely low and you're not doing big context switches, it's better to not use it. To quote another Stack Overflow post:
Quote
EDIT: A question came up: "Does that mean I should use spinlocks wherever possible?" and I'll try to answer it:
As I mentioned Spinlocks are only useful in places where anticipated waiting time is shorter than a quantum (read: milliseconds) and preemption doesn't make much sense (e.g. kernel objects aren't available).
If waiting time is unknown, or if you're in user mode Spinlocks aren't efficient. You consume 100% CPU time on the waiting core while checking if a spinlock is available. You prevent other threads from running on that core till your quantum expires. This scenario is only feasible for short bursts at kernel level and unlikely an option for a user-mode application.
Here is a question at SO addressing that: Spinlocks, How Useful Are They?
So is there a good predictor of which software this affects most? Not really.
#devil'scanyonMR
"We also blind small animals with cosmetics.
We do not sell cosmetics. We just blind animals."
"Please don't mistake us for Equifax. Those fuckers are evil"
This PSA brought to you by Equifacks.
PMSL
So this would be for multithreaded applications that have to wait on a background thread to complete?
22 minutes ago, gabrielcarvfer said:
It benefits heavy parallel workloads with shit ton of threads with message passing/shared variables, that is not the case for the majority of software running on desktops. Probably hurts programs that used pause without a good reason. That stack overflow post saying that it's not efficient in user more is not really accurate, that will depend on how the thread is implemented on the system (library based or built into the kernel).
I believe the SO post mentioned it's not good to spinlock in userland space. In kernel space it's not as bad since the context switch isn't as painful.
No. It's only if the application is using a spinlock to wait for something. That something is not necessarily completion of a thread.
I'm going to hazard a guess that this only applies to Skylake-X and anything using Intel's Mesh Core Communication Architecture.
Quote
Yeah, which leads me to believe it's a Skylake-X issue.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
Fix title please, this is according to the source a Skylake-X HEDT exclusive issue.
Personal Desktop":
Luna, the temporary Desktop:
I'm sorry but when we're talking an increase of 10 cycles to 140 cycles in processors running in excess of 2 to 3 thousand million cycles per second this hardly seems like an issue
The slide deck says "as many as."
Also are you from the UK or abouts? :P
negative.
I'm from their prison island
I only ask because I noticed the way you said the number 1,000,000,000
yeah. i could have said billion as a regular number :P
When i was in school my programming/IT teacher always taught us that when talking about clock speeds and gigahertz that it should be referred to as thousand million instead of billion. no idea why, and i just ran with it.
I tried the test program that came from the article, supposedly my 6700K has this issue with .NET Core & Framework, I'm about to test it after installing .NET Core 2.1 and Framework 4.7.2
Any news? No issue, has the issue?
