Show off your old and retro computer parts
Message added by SansVarnic,
When posting with quotes, please be sure to exclude/remove/snip any photos from the quote to help with load times for slower internet connections.
Thank you,
Moderation Team
11 minutes ago, Bitter said:
I need to do similar and repair two older macbooks for my GF. I also may be in over my head.
Oldest Macbook I've worked on is an A1278, I have had several brought to me with failed boards. One water damaged, one dead GPU solder balls, one dead charging circuit. Not too hard to initially open but there were many different screw types and way too many screws overall.
Thankfully these all still run most of the time but very poorly, I don't even know what numbers or hardware they are. 2 of them are the old thiccboi.
Went and looked, A1260 and A1286.
Went to freegeek St. Paul today.
No pictures but wow did they have stuff (mostly from Computer Reset).
Bins of PCI cards and Slot 1 P2/P3’s.
A PowerBook G3 Pismo.
Two Mac Pro 2010s
An 8” floppy drive
iPods galore (they didn’t have any Touches though)
A PCIe x4 Blackmagic Studios card that I think was an old Mac capture card?
Bunch of IDE, SATA, and SAS hard drives
A light-up P4HT signpost that my dad sadly wouldn’t let me get. Yes, it did overheat.
A cursed iPad 4 that had no square on the home button
And then I got:
- PS2 network adapter for $2
- iPad camera kit in box for $1
- Replacement heat sink for my Power Mac G4 for 50 cents
- Anti static bags
elephants
13 hours ago, 8tg said:
I have bit off more than I can chew
this is such a complicated machine, it’s genuinely impressive what some of the workarounds were at the time to create such a thin and light laptop
Update, straight into the garbage. Just when I got all of the rubberized coating off the palmrest, it started getting sticky everywhere else. Along with that the majority of this machines bodywork is tape and glue, I was thinking I could remove the adhesive on the speaker grilles and use some double sided tape around the edges to replace it.
No, they crumbled immediately.
the entire chassis flexes, it’s covered in these annoying adhesive panels that cover up holes, some of these panels are the size of a credit card and are covered in crumbs, the Heatsink is anemic and can’t even cool the 7 watt 1.2ghz core2duo in there.
The rubberized coating makes it look like ass, it has the worst keyboard I’ve ever used of this generation, it’s flimsy and this never should’ve been called a thinkpad.
I hate throwing away a machine like this, but there is no saving this hardware, this is garbage and I see why nobody likes them.
My step dad is really impressed with his £220 Thinkpad L480.  So my Mum ended up paying for it as a birthday present for him
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
For those with Socket A systems that still function - you really aren't missing out on much if anything at all by comparison to socket 370 and Coppermine/Tualatine in regards to performance. Definitely won't have as many reasons to use my Abit VP6 and Jetway994AN-L:
Lo-Cost Duel: Duron 1100 vs. Celeron 1200 - THG.RU
"We also blind small animals with cosmetics.
We do not sell cosmetics. We just blind animals."
"Please don't mistake us for Equifax. Those fuckers are evil"
This PSA brought to you by Equifacks.
PMSL
On 5/23/2022 at 9:26 AM, Mel0nMan said:
Could take the heatsink off, much easier to ship then
well they're gone
Need to get the LCD working again, but this is my grandfather's Toshiba T3100. When the LCD was working it had some DOS games like MathBlaster that still worked.
If I can't get the LCD working again, I might try turning this into a sleeper cyberdeck.
Also, the buckling spring keyboard is amazing to type on, 10/10.
Not mine, but on a visit for cleanup/repair.
Before:
After:
Forgot to take a picture but the LCD had about 10 columns missing, that was surprisingly successfully repaired.
2 of them, 2nd just needs cleaning.
F@H
GPD Win 2
The issue was the actual connection between the glass and the fine flex, the trick of putting some kapton tape on top and then going over the whole thing with a 250°C iron with flat tip worked
F@H
GPD Win 2
I'll remember that if i ever have any issues with my Pocket
Clean build...but another repaired mobo needs more caps replaced. Might be the board it came with - but I'm switching over to the SE440BX-2. Old reliable and I can use my PIII.
20220602_190635.thumb.jpg.aae23d69dd6dcaab52660bdeb71adac0.jpg20220602_190713.thumb.jpg.6562bb6c95bcd58fc54656dc5845c967.jpg20220602_190659.thumb.jpg.fc9ddbfc45d8b0751345eb4e9e8ada55.jpg
PMSL
I have a Toshiba T1000 with the original box. It still has the original owners info on it lol.20200527_094234.thumb.jpg.21a042a861a0c463eb9a8ca94c2167ec.jpg
  • CPU: AMD Ryzen 2700X
  • Motherboard: MSI X470 Gaming Pro
  • RAM: 32 GB HyperX Fury DDR4 2400
  • GPU: MSI 5700XT MECH
  • Case: Fractal Define R5
  • Storage: 1TB WD Black 7200 RPM HDD, 2TB WD Black 7200 RPM HDD, 4TB WD Black 7200 RPM HDD, Samsung Evo 960 1TB SSD
  • PSU: Corsair CX750M
  • Display(s): HP 24W
  • Cooling: 1 120mm Corsair fan, Noctua NH-U14S
  • Keyboard: Razer Blackwidow 2016
  • Mouse: Razer Deathadder Basilisk.
  • Sound: Razer 7.1 Kraken Chroma V2, LG SJ4Y 300W soundbar
  • Operating System: Windows 10 Professional 64 bit
Going back to my more stable "450A" from the "500". And I have to pencil mod them to 66mhz:
Cooler came on the 300A. Best Celeron ever made.
PMSL
There is an old computer my father got handed to him from family back when I was like 6 years or so of age and it had giant floppy disks, I played an aircraft game on it, if I recall you could shoot things and you had to try and get to the end of the level, the screen was green. The keyboard had a spring loaded wire.
I to this day have never found the exact model.
Cash Dump: 5800X. 32GB Ram. x570 motherboard. RTX 3070. 1440P screen.
Parts list: https://uk.pcpartpicker.com/list/RJhfPX
Finally finished the build side of things. Working perfectly - though my PIII 650 seems to be dead...so Celeron 300A:
PMSL
49 minutes ago, Schnoz said:
Neat! You might want to see how far you can overclock that Celeron. If I remember correctly, damn near every single one of the things could run reliably at 450 MHz. If the motherboard prevents you from overclocking it, taping over Pin B21 should circumvent that:
Already done - went all in and cut the trace on the 300A and one of my 333. Unfortunately my only board that could overvolt the 333/500 doesn't work.
PMSL
On 5/15/2022 at 10:10 PM, Mitko_DSV said:
I have a similar PC:
AMD Athlon64 x2 4600+ 2.4GHz
4GB DDR2 800MHz
MSI nVidia GeForce 9500GT 1GB
Haven't tested how YouTube runs on Win 7, but on Win XP SP3 it can play perfectly 1080p video from YouTube (tested in Chrome and Firefox) and the CPU sits at 50-60% usage even. Don't have a recent picture of it inside or running, but here's how it looks outside and the setup. Both Windows versions are on different 80GB SATA HDDs. The HDD that can be seen trough the hole in the front is a 500GB one and I use it as a backup (usually not plugged in when using the PC). The Win 7 install I use for testing HDDs/GPUs, but mainly HDDs in the front bay (the black one in the third 5.25" bay), can't remember what it was exactly called, I guess I'm too tired to think properly. Some day when I have time I can take a picture of the inside and it running.
A few days ago had to replace the CMOS battery and remembered to take pictures. Here's the inside:
In the bottom of the case is a dead 80GB IDE HDD (I think it was a Seagate something), two 1GB DDR2 and a 2GB DDR2 stick of RAM, which are working, but for some reason the motherboard sometimes refuses to boot with all the RAM in it, so currently it only has a single 4GB DDR2 stick, not that more RAM would make sense when running XP SP3. The top HDD is a WesternDigital Raptor WD740 10000 rpm on which is XP and the bottom HDD is a 80GB Hitachi Deskstar 7200 rpm where Windows 7 Pro is installed for testing HDDs in the front bay or testing GPUs.
And from the outside:
In the box under the desk is my soldering iron. I use the keyboard tray of this tiny desk to solder, not the best place, but better than nothing.
Main PC: Acer IPISB-VR│Intel Xeon E3-1270 3.4GHz│AeroCool AirFrost 4 with Noctua NF-A9│16GB DDR3 1600MHz Dual-channel│nVidia GeForce GTX1060 6GB│Cricual MX500 250GB SSD + WD Blue 1TB 7200rpm + Seagate 1TB 7200rpm│Windows 7 Pro x64 & Windows 11 Pro│CoolerMaster Silencio 352M│Seasonic M12II-520 EVO 520W│Acer SA220Q 22" 1920x1080
Secondary PC: MSI H81M-P33│Intel Core i7-4790 3.6GHz│DeepCool Ice Edge Mini FS V2│16GB DDR3 1866MHz (1600MHz) Dual-channel│AMD R9 270 2GB│WD Green 120GB SSD + Seagate 1TB│Windows 11 Pro│Acer Aspire M1930 case│CoolerMaster B500 v2 500W│Samsung S19B300 1366x768 & Fujitsu-Siemens P15-1 1024x768
Test PC/Nice XP PC: ASUS M2N│AMD Athlon64 x2 6000+ 3.1GHz│CoolerMaster unkown model│4GB DDR2 800MHz│nVidia GeForce 9500GT 1GB│Hitachi Deskstar 80GB 7200rpm + WD Raptor 74GB 10000 rpm│Windows 7 Pro x64 + Windows XP Pro SP3│TurboX Case│Zalman 450W│LG Flatron L1718S 17" 1280x1024
Future workshop PC: ASUS M4N68T-M-V2│AMD Phenom II x6 1055T 2.8GHz│Some 130W tower cooler│8GB DDR3 1333MHz Dual-channel│AMD Radeon HD4670 512MB│Samsung Spinpoint 640GB 7200rpm│Windows 7 Pro SP1 x64 + Windows Vista Ultimate SP2 32bit│Medion MD8840 case│Antec VP350P 350W│Lenovo L220x. 22" 1920x1200
HTPC: HP Elite 8200 USDT│Intel Core i7-2600s 2.8GHz│6GB DDR3 1333MHz Dual-channel│Intel HD Graphics 2000│WD Blue 1TB 5400rpm│Windows 7 Pro x64│JVC LT-32VF30K 32" 1920x1080
New Main laptop: HP ProBook 455 G9│AMD Ryzen 5 2625U 2.3GHz│16GB DDR4 3200MHz│AMD Radeon RX Vega 7│1TB NVMe SSD│Win 11 Pro│15.6" 1920x1080
Old Main laptop: HP EliteBook 8470p│Intel Core i7-3610QM 2.3GHz│16GB DDR3 1600MHz Dual-channel│Intel HD4000 Graphics│Kingston 240GB SSD│Win 7 Pro x64│14.1" 1600x900
Secondary laptop: HP EliteBook 8470p│Intel Corei7-3520M 2.9GHz│8GB DDR3 1600MHz Dual-channel│Intel HD4000 Graphics│2 x Crucial BX500 500GB SSDs│Win 7 Pro x64│14.1" 1600x900
Main phone: Sony Xperia X CompactOther phones: Sony Xperia L3, Sony Xperia Z3 Compact (x2){and both are dead now}, Sony Xperia E3, Sony Xperia Tipo + 12 more (not going not list everything)
Most other PCs and laptops I own:
Small laptop: Acer Aspire One D255│Intel Atom N550 1.5GHz│2GB DDR3 1333MHz│Intel GMA3150 256MB│Western Digital 500GB 5400rpm KingDian S100 32GB Apacer AS350X 120GB SSD│Win 7 Ultimate x64 & Win 10 Pro x64 Windows Vista Ultimate SP1 32bit & Q4OS│10.1" 1024x600
Old secondary PC: ASUS A7V8X-X│AMD Sempron 3000+ 2.0GHz│Titan CPU Cooler│1.75GB DDR 400MHz│nVidia GeForce FX5700LE 256MB│2 x WesternDigital 40GB 7200rpm (sadly one seems to be dead)│Windows XP Pro SP3│Some case│Codegen 300XA 350W│Dell E173FP 17" 1280x1024 & Fujitsu-Siemens P15-1 1024x768Philips 200P4 20" 1600x1200
"The Old" PC: eMachines eTower 466i│Intel Celeron 466MHz│512MB RAM PC133│nVidia GeForce FX5200 128MB PCI ATi 3D Rage Pro AGP 2x_ 4MB│Seagate Baracuda 40GB 7200rpm│Windows 98SE & Windows XP Pro SP3│IBM P50 14" 1024x768 CRT
"The Floppy" laptop: Clevo 2700C│Intel Pentium III 1.1GHz│512MB PC133 SDRAM│SiS 630 32MB shared│Samsung 40GB│Windows XP Pro SP3│15" 1024x768
"The P4" laptop: HP Pavillion ZD8000│Intel Pentium 4 3.2GHz│2GB DDR2 666MHz Dual-channel│ATi Mobility Radeon X600 256MB│Seagate 100GB│Windows XP Pro SP3│17" 1440x900
Dell laptop: Dell Latitude D600│Intel Pentium M 1.6GHz│1.5GB DDR 333MHz│ATi Mobility Radeon 9000 64MB│40GB IDE│Windows XP Pro SP3│14.1"  1400x1050
Future workshop PC (dead): MSI MS-7302│Intel Core 2 Duo E7400 2.8GHz│Stock cooler│3GB DDR2 800MHz│AMD Radeon HD7470 2GB│Samsung Spinpoint 640GB 7200rpm│Windows 7 Pro SP1 x64 + Windows Vista Ultimate SP2 32bit│Medion MD8840│FSP Group 250W│Samsung SyncMaster 730bf 17" 1280x1024
Old Secondary PC: HP IPISB-CH│Intel Core i5-2320 3GHz│DeepCool Ice Edge Mini FS V2│8GB DDR3 1333MHz│AMD R9 270 2GB│WD Green 120GB SSD + WD Blue 1TB 2.5"│Windows 7 Ultimate x64│Acer Aspire M1930│CoolerMaster B500 v2 500W│Samsung S19B300 1366x768 & Fujitsu-Siemens P15-1 1024x768
Bit awkward since I used the connector from another cable. But it'll work:
This particular card is only good for SLI though as the output is faulty.
PMSL
Diasassembled my HP iPaq PDA today since I thought there was an issue with the backup battery and it needed to be replaced.
It was quite complex, even more difficult than some modern Android phones.
Here is its small Intel CPU
These rather shiny Samsung memory chips, 64MB each IIRC. Seems to be discrepancy whether they are SRAM or DRAM but SRAM seems likely.
I apologize for the residue on the top RAM chip and CPU, there was a sticker across them and I didn't want to damage anything removing it.
Holding its resistive touch panel at an angle under light allows you to see the small points that allow the resistive touch input to work.
Now, to figure out why it will not save information if the backup battery is rechargeable. Probably just needs to be left on the dock for a while.
They're rechargeable but dead by now regardless so won't charge anymore.
F@H
GPD Win 2
Newest additon to my AGP collection. Hopefully this 3rd Geforce 2 works. Unlike the one from my Uncle's old PC which has donated fan screws to my Vanta.
PMSL
It works perfectly (ignore my Live Value! - its been disabled until I install the better drivers). Cost only $9.99 as untested. $19.27 with postage. VGA output is bad at 1080p though. One area the FX5700LE is excellent.
PMSL
