Rgb hub
Go to solution Solved by thrasher_565,
sould be fine
Hey, I'm using a proart b760 mobo, I'm running 3 fans off the fan splitter that comes attached to my aio, that's in one header, and the other header, I want to put a rgb/fan controller that holds 3 fans and 6 rgb Is that too much for one header? I don't want to burn anything out
https://linustechtips.com/topic/1574412-rgb-hub/
